  • SN95 V6 Mustang Tech
Mis-firing. Why?
  • Thread starter Thread starter 66nightMARE
  • Start date Start date Sep 30, 2006
66nightMARE
97
Katy, Texas
Sep 30, 2006
  • Sep 30, 2006
My buddies g/f's 96 V6 is misfiring but not sure why. They had it "diagnosed" and it gave them a "PO301" code. He said it was the number 6 cylinder. Any help is appreciated.
Skymarshal
572
Dallas
Oct 2, 2006
  • Oct 2, 2006
My car ('01) does the same thing. It only misfires when I'm driving at a steady 2500 RPM or so, and when I pull the code, it's always a cylinder 6 misfire. I've checked the plug, wire, and connections.
Dunno why it does that. I just try to avoid steady RPMS around 2500 and it seems to be happy.
TheCrazy1
70
  • Oct 4, 2006
Another possibility is the coil pack. They seem to need replacement at around 90 to 100k miles. Also check for any cracks in the coil pack housing.
E
eprider
Fort Sill OK
Oct 17, 2006
  • Oct 17, 2006
i had the same problem with my car. it kept missing around 2500 RPM and game me P201. i replaced the plugs (they were fine), wires (they were fine), checked the resistance and replaced the coil pack (which was fine) and still couldn't figure out what it was. i sent some sea foam up the PCV valve one day, went to the back of my car to check the smog, then walked back to the front and noticed a trickle of exhaust coming out of my engine compartment. i determined there was a hole in the exhaust manifold gasket, replaced it, and the problem hasn't occured again.
'66 coupe
1,202
9
59
Lakeland, Fl.
Oct 18, 2006
  • Oct 18, 2006
My #1 coil went out just before 80k miles.
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
New misfire after replacing valve seals/springs.
  • SpeedofDarkness
  • Aug 24, 2025
SN95 V6 Mustang Tech Aug 24, 2025
SpeedofDarkness
C
Knocking after pull- went away?
  • Connormcclark
  • Oct 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 6, 2025
gkomo
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
SN95 V6 Mustang Tech May 23, 2026
DPP
D
