The other day I pulled the spark plug on cylinder two on my 06 gt just to do a routine check up (I was having no problems beforehand) and after putting the plug back in noticed the idle seemed rough. I had accidentally dropped the plug before I put it back in, but didn't notice any cracks or signs of damage from the fall. I drove around for a bit, came home and let the car sit then left for work a few hours later and noticed the check engine light was coming on with a P0302 code (cylinder two misfire). The plug had looked a bit beat up but was running fine beforehand, connections were fine, and the coil must have been fine as well.
A few hours ago I had a friend come over to see if he could help me out, and we decided to pull the plug on cylinder 1 to compare as he was convinced the gapping on the plug on cylinder two was wrong. Make a long story short, we couldn't get the plug out on cylinder one and I didn't want to force it too much with all the horror stories floating around of spark plugs breaking in half and getting stuck within the block.
We fired the car back up after putting everything back, and now I'm getting a CEL with P0301 (misfire on cylinder 1) P0300 (random misfire, I'm assuming this is actually from cylinder two but the computer is picking it up as random as the misfire is now coming from two cylinders) and P0000.
We both concluded it must be something with the connection between the coil on the plug as everything was running fine beforehand and we never pulled the plug on cylinder 1. So we messed around with the coils for a bit and got nowhere. We're going to give it another go tomorrow to see if we can figure something out, but until then does anyone have any idea what this could possibly be?
