  • 1994 - 1995 Specific Tech
Misfire or AODE?
  • Thread starter Thread starter Synned
  • Start date Start date Oct 20, 2006
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Oct 20, 2006
  • Oct 20, 2006
I think my trans is starting to act up again...I got it rebuilt less than a year ago and luckily its still under warranty.
While I'm driving...the car like jumps very slightly. Its like im running over a small bump in the road...a little less drastic. It kinda feels like a misfire as well. I feel it mostly in OD, but I can definetally feel it in other gears...but I definitely only feel it from 15-2000rpm's on very light acceleration, like when I'm crusing at 40 it's almost constant. It kinda feels like it slips for a half a second and then re-engages, though the rpms don't go up or anything.
Does this sound like a tranny on its way out?
Thanks guys
Joe
rebelleader
185
Homer Glen, Il
Oct 20, 2006
  • Oct 20, 2006
I am having the same exact problem on my '01 Auto.
Very interested in what others have to say...
gcomfx.com
3,690
Republic, MO
Oct 20, 2006
  • Oct 20, 2006
I don't run in O/D unless I'm on the highway. With a big stall I can't climb any sort of hill at 40mph in O/D without it stalling like a mofo.
The only weird thing mine does is load up and surge going downhill coming to a stop light.
Mustangless
903
home
Oct 20, 2006
  • Oct 20, 2006
I think mine is doing the same thing. Either that, or my spark plugs are messed up.
HISSIN50
34
129
Oct 20, 2006
  • Oct 20, 2006
Joe, do you think it could be a calibration issue (if you run Mercon)? It seems to me that is kind of what the MV fluid retrofit deals with.................
Good luck bud.
Oh, if the trans has a warranty and it's in effect, I'd get back to the shop sooner than later.
Synned
Mar 31, 2005
991
Philly
Oct 20, 2006
  • Oct 20, 2006
Is it bad if I have no clue what that means?
Swarzkopf
973
Pittsburgh
Oct 20, 2006
  • Oct 20, 2006
****in' A.
Again, mine does the exact same thing! Was kind of aggravating at first, but now I'm totally used to it.
HISSIN50
34
129
Oct 20, 2006
  • Oct 20, 2006
Not at all. The PCM and trans work together closely on the wonderful E-AOD. There can be calibration issues with Mercon, which is why there was a TSB back in about '97 recommending MV (Mercon V) for AODE's.
Because you're the one who knows the exact symptoms, I'd search in TCCoA's forums so you can pick up the fine details yourself (that I, or we, might miss or not know about).
A good first search would be something like "transmission shudder" or "converter shudder" and see if any of it sounds like what you are getting, Joe.
I'd add that a LOT of folks swear by Lubeguard (a 10 dollar additive). Jerry even mentions it in his articles. Honestly, I might try the Lubeguard first to see what it does, as that might be a clue (if it helps, it could be a fluid issue. If it doesnt, it might be something else). And remember to keep warranty timing in mind if it still applies (let it be someone else's problem).
Good luck bud.
gcomfx.com
3,690
Republic, MO
Oct 20, 2006
  • Oct 20, 2006
Good point. I have a redline additive in my fluid as well. I'm also planning to swap my tranny over to Amsoil this spring. Tranny fluid is like blood in our body. If it isn't right, it can give us the shutters too.
K
88 speed density misfire and bucking
  • kush
  • May 29, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
DadLife0724
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
D
Foxbody Misfire 5.0 Swap
  • DPORTER0729
  • May 2, 2025
Fox 5.0 Mustang Tech Jul 13, 2025
90sickfox
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
G
Sputtering/misfiring below 2500rpm
  • Godless
  • Sep 14, 2025
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2025
gkomo
