  • SN95 V6 Mustang Tech
Misfire problem solved!
  • Thread starter Thread starter Skymarshal
  • Start date Start date Sep 6, 2007
Skymarshal
572
Dallas
Sep 6, 2007
  • Sep 6, 2007
Several posts over the past year have dealt with a misfire people have had that has been intermittent, and usually occurs at around 2500 RPM. I had the same thing happen- except the occasional misfire turned into a cylinder that was dead most of the time. The engine lacked power, the CEL kept flashing, gas mileage went to crap, and the computer kept posting a code 306 (#6 cylinder misfire).
I replaced the coil pack, plug wires, and injector on that cylinder, and Seafoamed the engine (again) and cleaned the fuel system and air filter. I had good Bosch platinum plugs, and they tested good in impedance, so I didn't replace the plug.
Well, I was out of ideas, so I replaced the plug. And that was it! The porcelain insulator on the plug was cracked, and sometimes the spark would jump through the crack to the block, grounding the plug and causing a misfire. I know others have had the same problem, so it wouldn't hurt to change those plugs!
raz54
205
Eureka Ca.
Sep 7, 2007
  • Sep 7, 2007
The last time I replaced the plugs and wires on a Camaro I had with a 3.8 two of the wires and one plug were no good!!! The car ran better before the tune up so you're right, just because they are new doesn't mean they good.
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
SN95 V6 Mustang Tech Tuesday at 3:15 PM
gkomo
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
New misfire after replacing valve seals/springs.
  • SpeedofDarkness
  • Aug 24, 2025
SN95 V6 Mustang Tech Aug 24, 2025
SpeedofDarkness
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
