misfire problem
Once I had that probablem with a plug wire that was bad/arching on the headers. I have also seen it happen with using platnum spark plugs in 302 motors they don't really like anything but good old copper.
I t could also be the something in the emmissions system have you cleaning the IAC idle air control when they get carbon built up in them they can cause some really head aches.
It could be a MAF. I would try using some sensor cleaner and a Q Tip and cleaning the little heat element on the MAF first just be carefull not to break them the are sensitive and know to collect dirt. They get especially dirty when running cold air/ ram air intakes I would try that before changing expensive MAF units.
i think it started doin it after i over reved the motor after a missied shift now it messes up sometimes and mis fires
Sounds like a piston might have come in contact with a valve, bending either the valve head or bending a pushrod instead. A compression check will reveal if it's a bent valve, and you can pull the valve covers to inspect the pushrods.
