Hey folks, I've got an issue and I'm really not sure where to start. I'm hoping to narrow down the possible culprits before I just start replacing parts.
The main problem is limited to the right side. There is hesitation and a loss of power with popping in the right exhaust during acceleration between 2nd and 3rd gear. The problem isn't present at idle though I've noticed some very random idle surging at times. The popping isn't constant after the car warms up but the hesitation is still there.
While checking for vacuum leaks I found a rotted line from the intake to the canister purge regulator. Replacing the line didn't solve the problem but it did seem to make the idle a little stronger. The plugs, distributer cap/rotor, and plugs were replaced about 4-5 years ago. I'm still using the original wires and coil. When I started checking the ignition system I noticed a funny reading on the coil. The secondary resistance is within spec but the primary is reading virtually no resistance. Enough that it is triggering the continuity tone on my DMM. So I'm not sure if this means the coil is bad or not. The coil terminal and connecting wire looks pretty corroded and misshaped. I pulled codes and I'm getting 172 and 173, which means the right O2 sensor is faulting lean and rich.
Could a bad O2 sensor cause this problem or even the coil? I'll probably end up changing all the plugs again and maybe the wires (though they still look pretty good minus the coil wire). Has anyone run into this type of problem before and found a fix?
Thanks
Thanks
