I have a 1976 Cobra II with a 302 4 speed. When Im gunning the engine it misfires or "gurgles". I Really noticed it when I tried to dyno my car. I couldnt complete a full pull cause it was so bad. I have replaced the plugs and wires, but Im thinking I may need a coil, cap or possibly a distributor. What are y'alls thoughts on this? It has an edelbrock manifold with an edelbrock 4bbl Carb. Am I possibly trying to push too much fuel through? I am clueless, any help is appreciated!
it hard, while in gear, the car will bog out or "hesitate" then will go as normal after the hesitation. Not sure if this is your problem. Depends on the symptoms. I'm not a mechanic or anything so listen to some of the other advice on here. The AP is located on your carburator and will be somehow connected to the throttle - not sure how to test it though...
