  • SN95 4.6L Mustang Tech
Misfiring
  • Thread starter Thread starter Roger_4.6_96
  • Start date Start date May 30, 2005
R
Roger_4.6_96
1,209
Reno,NV
May 30, 2005
  • May 30, 2005
I have new plugs and wires with small missfire. What else could cause me to misfire ? Coilpacks have 100k miles on them. Could it be fuel injector or something fuel related ? Any help will be appreciated.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
May 30, 2005
  • May 30, 2005
any codes thrown? what does your O2 sensor voltage look like on a DSO? have you used and ful injector cleaner? could be the coil packs going.
R
Roger_4.6_96
1,209
Reno,NV
May 30, 2005
  • May 30, 2005
No codes thrown at all . I got one new 02 sensor in the front.
It seems to only misfire when it gets warmed up
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
May 30, 2005
  • May 30, 2005
what kind of plugs did you use? did you use antiseize and torque them? did you recheck the torque?
R
Roger_4.6_96
1,209
Reno,NV
May 30, 2005
  • May 30, 2005
You mean the gap ? There suppost to be gapped from the factory. I used ford plugs the platinum ones. I check the gap on one of them it was 52. I had a hard time getting them out so i havent checked the other ones yet.
I forgot to mention everything ran cool til i 175 miles.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
May 30, 2005
  • May 30, 2005
no i dont mean the gap. when you put them in what did you torque them down to. or did you just put them in hand tight? when i install plugs on mod motors i usually torque them to 180 in lbs.
R
Roger_4.6_96
1,209
Reno,NV
May 30, 2005
  • May 30, 2005
i dont have a torque wrench.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
May 30, 2005
  • May 30, 2005
then dont work on your car. a torque wrench is essential when working on your car. i have 5 torque wrenches personally, and i know some techs that have about 15, all different kinds.
very few people i know can work without a torque wrench, but theyve been doign it forever and know what their strength is. but they also use a torque wrench on almost everything.
R
Roger_4.6_96
1,209
Reno,NV
May 31, 2005
  • May 31, 2005
Ttt
R
Roger_4.6_96
1,209
Reno,NV
May 31, 2005
#10
  • May 31, 2005
  • #10
My fuel pressure is 34 psi when the car is turned on. Is my stock GT Fuel pump and tank enough for Cobra ?
9646gt
595
Holloman AFB,NM
May 31, 2005
#11
  • May 31, 2005
  • #11
Someone with more knowledge will have to chime in on the fuel requirements for the cobra swap as ti does have 2 more valves per cylinder ...but does it do it at WOT? if it does it is most likely not a sensor as most sensors are ignored at WOT ..
R
Roger_4.6_96
1,209
Reno,NV
May 31, 2005
#12
  • May 31, 2005
  • #12
Well i noticed that it would do it if i was low on gas. I filled her up half way and she seems fine now.
My GT radiator didnt have the fix. Could it be possible that it got hot and makes it mess up ?
9646gt
595
Holloman AFB,NM
May 31, 2005
#13
  • May 31, 2005
  • #13
not sure wich fix you are talking about in terms of the radiator...but it sounds liek your pump is really having trouble keeping gas to the motor...I never let mine get below a quater of a tank if I dont half to jsut becuase I have always heard its good to keep the pump submerged?
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
  • Gulftown980x
  • Jul 29, 2026
squeak93
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
