Misfiring
MyNewEdge
Alabama
Morning, so just over a month ago I shot a plug and took it in to have a helicoil installed and replaced all 8 plugs and coils at the same time. Just a few days ago I shot a different plug, yet again I had a helicoil installed with another new coil and plug. As it stands, it’s still misfiring and so I replaced the Ignition terminal connector to be safe and was running fine for about 3 different 5+/- mile round trips and then the last start up, back to throwing a code and running a tad rough. Any ideas?
Do the misfire codes correlate with the cylinders you had helicoiled? Not sure if your mod motor has Cops or coil packs-but maybe swap the cops around and see if the misfire follows, or switch the plug wire with a different plug wire if so equipped .
Also- welcome to Stangnet
:SN:
