  • SN95 4.6L Mustang Tech
Missed second!!!
  • Thread starter Thread starter hotmustang331
  • Start date Start date Oct 22, 2004
hotmustang331
2,967
Bastrop,TX
Oct 22, 2004
  • Oct 22, 2004
Ok so I pull up to a light after just filling up with gas and these to guys in an old chevy truck jump a little to try and race, so I give them the thumbs up, and roll down my window and answer their Qs about what kinda of mustang it is, then the light goes green so we both punch it.I pull ahead through 1st, the when I try to drop second, the freekin tranny STOPS me right before second (no grind, just stops) so it revs to like 6K and then I am like trying to get it to go in, then it decides to let it go and I squeel 2nd pretty good with the high revs...even though I still murdered the truck, it made me freekin mad. So I decide to try again down the highway, slow roll in 1st, nail it try and shift to 2nd, DOES IT AGAIN!!!Just stops.So I slow down and have another go at it, run through 1st SLAM it and this time it goes but almost stoped me again, even twisted my nob making it go(still hit 3rd though LOL).So whats with this???Is this some freek thing where my trans screwed me over, and made me look like an idoit missing 2nd or is this some tranny problem, like that grind thread? This is the FIRST time to miss ANY gear when speed shifting after installing the pro 5.0 and have only messed up once before when cruzing when I went from 4th back to 3rd at low RPM when trying to hit 5th.I am going to try this 1st-2nd thing again in the morning when I go to work.Jeeze this just eats me up for some reason LOL.BTW there was a cop just after I raced that truck, I let off at about 50-55 in a 45.Pheew. Thanks for any help guys.
crew_dawg16
445
DeKalb, IL
Oct 22, 2004
  • Oct 22, 2004
maybe try shifting at 5500 rpms and see how it works for you
Marks5.0!
640
San Antonio, TX
Oct 22, 2004
  • Oct 22, 2004
mine does that as well on the 2-3 shift at anything over 5500 rpms.
Dan_Soprano
7,410
54
129
Jacksonville, FL
Oct 22, 2004
  • Oct 22, 2004
syncros going bad. how many miles on it?
Nuar
570
NB, CT
Oct 22, 2004
  • Oct 22, 2004
i know exactly what youre talking about!!
i had that same problem!
since then i got the PRO 5.0 shifter and it didnt help at first but here is mysuggestion... (might not be the best one)
When youre about to shift into second... as the RPMs climb,, pull down on the shifter a little bit,,, just to put pressure on it,,, you got a new clutch so it will not pop out of the gear, then when your ready to shift, press the clutch and pull harder,,,, before you know it the shifter will be in second and youre good to go...
For some reason i couldnt do that too well on the beginning, and right now i can slam through gears no problem, maybe the shifter needs a little time to break in... give it a try, send me a PM and let me know if it worked for you too
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
