Missing ac parts...
  • Thread starter Thread starter billison
  • Start date Start date Feb 15, 2013
billison
I like tinted tail
2,607
1,094
184
stl
Feb 15, 2013
  • Feb 15, 2013
Alright I'm going to start off by apologizing isn't try the best I can see you Saries talk to text to do this
Alright I went and looked at an 89 GT today
I am possibly Fradine my 92 LX for it
One of my only hangups with this car is the air conditioning is not currently working
I don't know the proper names to all the components so please forgive me, Both of the hoses that come out of the air compressor were completely missing, I also could not find the wires that connect to the compressor although I was not 100% sure what I was looking for, I'll be comparing it to my 92 in the morning
The part that goes into the cabin as well as the part that sits in front of the radiator were both there.
Assuming I have to replace the pump what all will I need to have a functioning system?
The high side and low side hoses are obvious on the firewall where the two tubes go into the cabin's on of the stuff that's normal leave there was there
I would like to use r134a.
billison
I like tinted tail
2,607
1,094
184
stl
Feb 15, 2013
  • Feb 15, 2013
I'll be looking at my air-conditioning set up on my 92 in detail in the morning so many of these questions may be answered by that
Mustang5L5
Mod Dude
Feb 18, 2001
43,361
18,107
224
Massachusetts
Feb 16, 2013
  • Feb 16, 2013
If the hoses were left open for a long time, it's possible the inside is rusted, or corroded out. You can try flushing it, buy its possible they need to be replaced.
The ac compressor wiring is a simple 2-wire plug that comes from the starter solenoid area. It may be hanging loose, or possibly unplugged and removed.
My total cost in parts to reinstall the ac system on my '88 was approximately $500. That's all new Ford components, rebuilt compressor and using r-12
Sent from my iPhone 4S using Tapatalk
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 16, 2013
  • Feb 16, 2013
Since you are not familiar with how A/C works, here some background theory:
The condenser is up front of the radiator, and it is supposed to condense the hot gas from the compressor into a hot liquid. The hot liquid goes to the expansion valve located in the tubing next to the firewall. The expansion valve lets the hot liquid expand and become a cold gas, the cold gas goes to the evaporator inside the car where the fan blows on the evaporator exterior. The heat transfer from the air inside the car to the cold gas inside the evaporator causes the A/C to blow cold air. The now cool gas goes to the compressor where it gets compressed again into a hot gas and the process starts all over again. Keep in mind that this is a closed system, and the gas inside the A/C doesn't get out unless there is a leak, which is where you are at.
Here's where the problem gets sticky. All the original fox body Mustangs were made to use R12 refrigerant. R12 is no longer available unless you have an EPA 609 license or ignore the law and buy it off eBay.. That means the system needs to be converted to use R134. Putting R134 on top of R12 without doing a proper conversion will cause compressor failure and metal from the compressor will circulate throughout the system. When this happens, it requires an extensive and expensive flush of the A/C system to get all the metal and other contaminants out. Skip doing the flush and clean thing and the new compressor will quickly fail.
When a R134 conversion is done, the installer is supposed to replace the service fittings with R134 style quick connector couplings.
Typical low pressure side R134 coupling
Typical high pressure side R134 coupling
Then he places a R134 conversion sticker on the car. The typical sticker looks like this, yours may be different.
They are also supposed to replace all the O rings with R134 compatible O rings. The R134 gas molecule is smaller than the R12 molecule, so R12 O rings will be prone to leakage.
See http://bellsouthpwp.net/l/r/lrichker/Mustang_tech/R134a_conversion/r134a_conversion.htm for R134a Conversion & recharge help
If the gas leaks out, usually it is because one of the O ring seals is bad. High quality R134 conversion is supposed to include new green O rings for all the joints and couplings. When you open the system to replace the O rings, all of the refrigerant must be removed and recovered and the system vacuumed down prior to recharging.
R134 recharge kits with refrigerant/leak detector dye can are available at most auto parts stores. Some of the R134 refrigerant refills have a leak stop in them. BUT beware! The stop leak can block the expansion valve, causing system failure. The refrigerant/dye recharge kits are popular because the green dye makes a very visible indicator where the leaks is. Some of the recharge kits include a pressure gauge so you have some idea of how much refrigerant is in the system while it is running.
R134a Air Conditioner Conversion and recharge instructions
Revised 23-June-2012 to include green R134 compatible O rings used for O ring replacement and R12 charge instructions
Color Legend:
R134 specific items and instructions are in red text
Freeze 12 specific items instructions are in indigo text
Note: R12 is available on eBay. Use the Freeze 12 instructions except use the R12 36 oz refrigerant charge with R12 refrigerant
Items and instructions common to both R134 and Freeze 12 are in black text
Tools and materials you will need:
Gauge set for recharging = $20-$120 – check out the pawn shops for a bargain before you pay retail.
See Harbor Freight Tools for an inexpensive gauge set.
Vacuum pump – I use an old refrigerator compressor = $20- $40 at used appliance stores, or go to the Dump and get one for free. Be sure to have some R12 compatible oil handy to keep it lubed up properly.
O ring seal kit = $8.
Replacement accumulator/dryer assembly with hose $55-$75
Alternative refrigerant – Freeze 12 – it will allow you to skip flushing the system and reuse the original accumulator/dryer under certain conditions:
1.) If the A/C system has not been open to air for more than an hour or so.
2.) Or if it hasn’t out of refrigerant for more than 5-7 days and the system is till sealed up with no open or disconnected lines.
If either of the above is not true, you must replace the accumulator/dryer assembly.
Freeze 12 refrigerant: $15-$16 per 12 Oz can on eBay. Get 3 cans, 2 for the initial charge and 1 spare for a top off charge.
Use R12 compatible mineral oil, 6-8 Oz. This may be difficult to find or expensive (~$20 a quart)
Do not use PAG oil in a Freeze 12 system without flushing it first.
Freeze 12 refrigerant charge= 26-28 Oz plus 6-8 Oz R12 mineral oil on an empty system. A recharge may only require 2-4 OZ of R12 mineral oil if you only replaced a line, hose or seals.
A/C systems that have had a compressor failure must be flushed. Failure to do so will result in the floating trash left behind from the compressor failure destroying the replacement compressor.
R134a = $11-$16 a can – takes 2 cans.
R134a PAG or Ester compatible oil = $7-$12 for an 8 oz bottle .
Pump to force cleaning fluid through the system $20-$50 (may use compressed air to do the same thing).
R134a charging adapter = $13 (I cut mine up to use it with the R12 gauge set that I have had for a long time).
Plastic tools to disconnect refrigerant lines - 1/2" & 5/8" = $4 each.
Flushing agent - Discount Auto Parts has some flushing solvent in a 1 gallon plastic bottle - try that first. Or use Mineral spirits = $4-$5 a gallon, tetrachloroethylene =$5-$10 a gallon, takes 2 gallons of either one.
Miscellaneous hoses and fittings to adapt the flushing pump to the system, and the R134a adapter to the R12 gauge set = $15.
R134 Refrigerant charge is 26-28 Oz plus 6-8 Oz of PAG 100 oil.
R134 Conversion Instructions:
I did a R134a conversion on my 89GT, and used all stock parts. You will need to replace the dryer/receiver (about $75 if you get the one with the hose made as part of the unit), and should replace all of the rubber "O" ring seals as well. You will need to drain all of the oil out of the compressor and replace it with new R134a compatible oil.
R134 instructions (skip this if you use Freeze 12)
Keep in mind that to fulfill the requirements of the EPA, you are required by law to recover any refrigerant that still remains in the system. How (or wither or not) you accomplish this is up to you. Connect the charging gauge hoses to the service ports on the A/C (red gauge = high pressure, blue gauge = low pressure) and open the valves on the gauges to dump the remaining refrigerant (if any) into your "freon recovery system", whatever it may be. Disconnect the charging gauges since you are finished with them until you are ready to fill the system with R134a. Next comes the nasty part – in order to get all the old oil out of the system, you will need to flush it with special flushing solvent, or mineral spirits (ok) or tetrachloroethylene (better, but may be hard to get). If you leave the old oil in place it will congeal and reduce the heat transfer in the condenser and evaporator (read that it won’t cool good) and possibly damage the compressor.
Disconnect the compressor and remove it from its mount to flush it with cleaning solvent. Pour about a cup of solvent into the suction port and turn the compressor center hub about 10 turns while shaking the compressor to move the solvent around inside the compressor sump. Drain the flushing solvent out and continue to turn the center hub by hand to force out any remaining solvent. Then fill it with oil: add about 6-8 oz of the new oil to the compressor large suction fitting. Turn the compressor center hub about 20 turns as you turn the compressor face up and face down to distribute the new oil inside the compressor. Catch and replace any oil that comes out of the compressor.
Connect the pump (I had an electric sump pump I bought for $20) to the hose from the high-pressure side of the compressor. Alternately, you could use compressed air to force the cleaning fluid through the system. I didn’t like to do this since compressed air has lots of moisture in it, which is death to A/C systems. Pump the cleaning fluid through the system and let it come out the hose that was attached to the old dryer/receiver. I used 2 gallons of mineral spirits and pumped it all through the condenser and evaporator. The expansion valve is located near the firewall in the high-pressure line of the evaporator, and may cause the cleaning fluid to trickle through the lines at a very slow pace. You may want to pump cleaning fluid through the evaporator and condenser separately to speed up the process.
Both R134, Freeze 12 & R12
Next comes the changing of all the old "O" rings so that the chances for leaks is minimized. The new R134 compatible O rings are green colored, so be sure that the replacement O rings are green. Use the plastic connector tools to separate the lines, place the extended collar part of the tool so that it faces the large part of the connector and push inwards: this expands the spring so that you can pull the tube apart. You may need a helper to push on the tool while you pull on the tubes to separate them. Install the new "O" rings: be sure to coat them with new oil when you put them in. Install the new dryer/receiver, refrigerant service port adapter on the compressor, add about more 4oz of oil to high pressure line and tighten up all the lines. Close the hood, start the engine, let everything get warm under the hood, but don’t add the refrigerant or turn the A/C on. Connect the charging gauge hoses to the service ports on the A/C (red gauge = high pressure, blue gauge = low pressure) and open both valves, then connect the center hose to the vacuum pump. The purpose of this exercise is to heat up the system so that when you vacuum it all down (yes, you will need a vacuum pump- mine is an old refrigerator compressor), that all the air, vapor and moisture from the cleaning fluid vaporizes and is removed from the system. Vacuum it down for about 30 minutes, this should give you about 28" of vacuum or more inside the A/C system. I have a vacuum gauge "T" connected into the vacuum pump line so that I can accurately watch the vacuuming process. This is a good time to take a soda and sandwich break since it doesn’t go faster if you watch it.
the R134a service fittings on the system: the red goes on the high side and the blue on the low side. This will help others identify that a R134a conversion has been done on the system.
Charging instructions for both R134, Freeze 12 & R12:
Remove the electrical connector from the dryer/receiver and jumper the two connections inside the wiring harness side of the connector together: this allows the compressor to engage in spite of low pressure/no gas in the system. Close both charging gauge valves, and then disconnect the center hose of the charging gauges from the vacuum pump and connect it to the refrigerant can tapper. Put the refrigerant can in the can tapper and screw it down with the can tapper valve closed, then open the valve. Loosen the hose at the center connection of the charging gauge set until the refrigerant squirts out: this purges the line of air and moisture. The refrigerant is added through the low pressure side of the system, so open the low pressure gauge valve to add the refrigerant. Start the car and take note of the idle speed, then set the idle speed up to about 1200-1500 rpm, and turn the A/C on inside and set the fan speed on high. Watch for the pressure on the low side to drop off as you are filling, and the refrigerant can will get warm and stay warm. This tells you the current can is empty and needs to be changed for a fresh one. Before you disconnect the can, be sure to close the valve on the refrigerant can tapper.
Watch the high side pressure on the charging gages and regulate the adding of gas to keep the high side pressure under 350 psi. You will probably need a fan in front of the car to keep the readings below 350 psi. I had to put the refrigerant can in hot water while I was charging the system with it, or else the can got so cold that it quit flowing. Use caution when you do this so that you don’t get water in the charging adapter when you change the cans. When you have added the 2 cans of gas, the high side will read about 250-300 psi and low side about 28-38 psi. Turn the idle speed back to where it was, turn the A/C off, disconnect the charging gauges, and re-install all the caps on the service ports. Remove the jumper from the low pressure switch harness and plug it back on the switch connectors.
R134 only
Then put the R134a Service Sticker on, secure all the loose wiring on the system and you are done.
I hope it cools good, mine doesn’t get quite as cold as it used to driving around town.
The above technical note is for informational purposes only, and the end user is responsible for any damages or injury. The end user bears all responsibility for proper recovery/disposal of any R12 refrigerant.
I have an EPA 609 MVAC certification. And yes, you can shortcut the process, but there are negative factors if you do. Sooner or later, something will cease to function like it should. Shoddy work is a time bomb ticking away, waiting to explode.
billison
I like tinted tail
2,607
1,094
184
stl
Feb 16, 2013
  • Feb 16, 2013
Alright if I'm reading all this correctly I'm going to need the new dryer and all the hoses but everything else seems to be intact minus some electrical leads
I am not going to plan on replacing the Evaporator or condenser But with all the hoses missing as well as the dryer I'm just going to go ahead and purchase them
And make sure they're capable of using r134a.
Again this is only if I get the car I'm not positive I want to trade yet
billison
I like tinted tail
2,607
1,094
184
stl
Feb 16, 2013
  • Feb 16, 2013
I assume if I have to replace the condenser or whatever part is inside the cabin that it's going to be a lot like replacing a heater core?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 16, 2013
  • Feb 16, 2013
Yes...
Get out the band-aids and be prepared to do some grunting and sweating... No repair is complete without a blood sacrifice of some sort.
billison
I like tinted tail
2,607
1,094
184
stl
Feb 16, 2013
  • Feb 16, 2013
Would the evaporator on my 92 be much bigger than on the 89?
2000xp8
SN Certified Technician
Aug 8, 2003
8,068
1,654
194
NJ
Feb 16, 2013
  • Feb 16, 2013
The evaporator is the one inside the car.
It's damn near impossible to replace. Ya, it can be done, but you pretty much need to remove the entire dash, pull the box out, then pray you don't destroy the box trying to get the evaporator out, it's permanently sealed in the box, unlike the heater core.
I tried getting it out, gave up and just had 99-04 ends welded on mine while it was still in the box, that's how i adapted the 4.6 a/c to my car when i did the conversion.
billison
I like tinted tail
2,607
1,094
184
stl
Feb 16, 2013
#10
  • Feb 16, 2013
  • #10
We'll see. I'm gonna post in the talk section about the trade and get ideas.
P
I need definitive heater valve and AC expansion valve answers
  • PurAU
  • Sep 26, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 1, 2026
GypsyR
G
G
2005 Mustang GT AC cycling on and off every minute
  • GeorgeSwadling
  • Jul 12, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 12, 2025
GeorgeSwadling
G
M
  • mnky99
  • Sep 5, 2025
mnky99
M
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
