Ok guys, I was able to take a good look at it after work today. I will start with what is correct; Manifold vacuum line to distribution block, brake booster, A/C system lines, cruise control line, FPR line, PCV line. Now for the problem areas. Fist problem noted was that the vacuum line coming out of the manifold to the front of the engine goes to the valve but then is just hanging off after that. It does not coonnect to the charcoal cannister, i dont even see it. Where is it supposed to be? Probably removed by previous owner. Next, there is no line going to the EGR valve, and there is what looks like a solenoid of some sorts on the rear pass side of the engine bay that has two vacuum ports, but no hoses (has wiring harnesses attached to it) Im assuming this is the EGR solenoid. Next, there is a little line coming from the back of the plenum that goes nowhere, looks like hose was removed. Also, going from the diagram posted above, there is no check valve anywhere, gues that whole section of hose was removed. Basically, everything on the pass side rear of the engine bay is gone. However, my HVAC controls all work fine, but there are no lines where is is supposed to be? Also, there seems to be no vacuum cannister. Lastly, where are the lines for the smog equipment? Diverter valves, etc? Sorry for the long post, but I am not too familiar with these cars yet. Im usually pretty good with this stuff, but the diagram doesnt seem to match up to the actual application to well. Is there a more relatable diagram anywhere, or would someone mind posting pictures of their actual engine showing these lines hooked up? Really want to get this situation worked out, because everything else on the car is excellent. Thanks in advance for any replies
