Missing
drewzx3
411
Louisiana
My car keeps getting an intermit miss. It does happen every time but every now and then I will crank it up and it misses and doesnt quit that day. Then the next day it wont do it. I have put a new distributor in it and new plugs, have tested the coil and it tested out ok. What should I throw at it?
If it really just comes and goes, if you have a spare EEC, swap it in. If you don't, do NOT go buy one. It's a guess and not worth spending money on.
Otherwise, get it to miss and run a cylinder balance test. This will tell you which cylinders are missing. Also make sure your EGR is not sticking open.
Yeah it did it before I put the plugs and dizzy in. It has did it off and on for awhile. I put a fuel filter on it probably a year and half or 2 years ago. The egr is deleted so that aint it. I dont have a spare ecu. How do you run a cylinder balance test?
