I bought a 95 Gt Automatic a few weeks ago and it was running at first but had an idle surge. While trying to get the figured out I started for the first time one day and it died within 10 seconds and hasn’t fired back up since.
I hear the fuel pump prime and am getting fuel pressure
I used noid light injectors are firing
I have spark at coil and spark plugs although it does seem a little weak (small orange not blue)
I used continuity light at coil to test Tfi it seemed good
I’ve tried adjusting the timing and did a compression test
My cel lights up when I turn key on and goes away while cranking
The only code I get consistently is 327 (egr valve) which previous owner removed
I’m lost at this point what is the next thing I should be looking at?
