  • SN95 4.6L Mustang Tech
Missing
  • Thread starter Thread starter HeMiBoB
  • Start date Start date May 8, 2011
H
HeMiBoB
  • May 8, 2011
Started missing last night the car has a LOT of mileage but runs well, doesnt burn oil or smoke at all. It went away and now its back...
I have a Diablo Predator Tuner but it didnt show any trouble codes, other than a O2 Sensor, which I have known about. The car idles OK but mostly lugging down low it's miss is the worse.
My wifey's Mercury Gran Marquis shows what cylinder and etc when it was a miss fire, I just replaced a Coil pack.
Is there anyway to run this Diablo Tuner and monitor Live data? It came with the car and has no manual etc.
H
HeMiBoB
  • May 8, 2011
BTW
car is mostly stock 99 GT with stock engine etc.
H
HeMiBoB
  • May 8, 2011
OK
Retrived Trouble codes..
P0602- Replace PCM .... WTF??
P0605- PCM "ROM" Error
P1211 ???
P1690 ???
P1000 Monitor test Incomplete
P0135- Upstream heated O2 sensor Fault
So I have owned the car for about a month. The car had No Check Engine Light on and ran well, but the clutch was toast...
I install a new clutch setup, of coarse the battery was unhooked.. But has been running well.. running great actually. But I think I broke the O2 Sensor during the clutch job...
I might be able to jerry rig the broken end IDK....
Anyways, the car had the miss as described...
H
HeMiBoB
  • May 8, 2011
OK Diablo boots up and says P0602 P1211 P1690 P0605 are normal...
The only codes I have then are a P1000, so I just reinstalled the HP tune on the Diablo..
And P0135 which I know is a O2 sensor. I was thinking I could turn this one off with the Programmer.. But not sure....
Maxpowers
859
Pittsburgh, Pa
May 8, 2011
  • May 8, 2011
Miss under load is a common symptom for ignition. Heck your wires and plugs. Then your COP's.
trinity_gt
3,125
81
99
Canada
May 8, 2011
  • May 8, 2011
Hmm. P1211 and P1690 don't seem to apply to your car/engine. I believe P1211 (injector control pressure" and P1690 (wastegate solenoid) are for Powerstroke diesel apps. I did a search and found another instance of someone reporting these codes from a Diablo Predator on allfordmustangs:
codes with the predator tune.PO602,PO605,P1211,P1690, - Ford Mustang Forums
It's almost like an upload didn't complete successfully or was corrupted etc. Can you return the car to the OE tune stored in the Predator?
H
HeMiBoB
  • May 8, 2011
Yes
I actually reloaded the HP tune from the Predator tonight... It still missed however.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
  • Gulftown980x
  • Jul 29, 2026
squeak93
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
