  • SN95 4.6L Mustang Tech
mixing tire sizes..
  • Thread starter Thread starter 40th GT
  • Start date Start date Aug 7, 2004
40th GT
916
Lawrenceville, GA
Aug 7, 2004
  • Aug 7, 2004
I'm thinking about saving some money and getting the 255/45/17 Nitto street radials for the rear, and keep the stock Goodyears up front until they wear out. Is this going to be unsafe for everyday driving?
BadMoFo
I will sleep with a Mod for a CT
2,911
New Bern NC
Aug 7, 2004
  • Aug 7, 2004
no, you can put different size tires on and it wont affect anything other than being able to rotate them. I have been running 265 on the front and 285 on the rears for about 2 years now. I just replaced the rears not to long ago and I probably have anouther 5k miles left on the front or more.
StangFreak32
75
Baton Rouge, La
Aug 7, 2004
  • Aug 7, 2004
i think i would skip out on the nitto and try to find a 255 goodyear tire with the same tread as the stock ones seems to me u would want similar tread for ur tires....course i may have no clue what im talking about
holler
332
Chicago
Aug 8, 2004
  • Aug 8, 2004
as long as you have the same tread on the same axle you're ok. In snow, I would reccomend all the same tread (ideally winter tires)
cobrahissss
37
Seneca, SC
Aug 8, 2004
  • Aug 8, 2004
Speed rating check
For everyday driving with some hustle especially in turns speed rating should be real close. If they both are 'V' or 'Z' should be no problem. If the Nitto are 'H' or less and they are on the back the slip angle (grip) of the higher speed rating on the front may cause lower speed ratings on the rear to break or swing out. I would think the blimp guys are Z rated.
M
Rim suggestions
  • mason5.0
  • Sep 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Qtrhrse23
305-45-17 tires on Pony wheels (17")?
  • TTSaleen
  • Mar 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 25, 2026
TTSaleen
O
Good all around perfornace-ish tires?
  • optionizerSS
  • Jan 25, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jun 15, 2026
TPony
H
Best tire size for 91 Fox 18x9 wheels. On coilovers
  • hassler
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
KRUISR
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
