  • SN95 4.6L Mustang Tech
MM C/C Plates Spacers ???
  • Thread starter Thread starter ToplessStang
  • Start date Start date May 14, 2005
ToplessStang
591
Montreal, Canada
May 14, 2005
  • May 14, 2005
MM C/C Plate Spacers ???
I'm doing the install now and was just wondering how many spacers some of you with H&R SS have used. Right now I put one thin spacer under and 2 thick and 1 thin over the top bearing. Seems to clear the hood ok but I'm curious what setup others have used. Thanks
Green Flea
28
California
May 14, 2005
  • May 14, 2005
I think I ended up using all of the spacers.
nyuk98gt
1,427
Chesterfield, MO
May 14, 2005
  • May 14, 2005
ToplessStang,
You have to trial fit the spacers until you have the strut tips just miss the underside of the hood. In my case, my stock clearance was 3/4" (19 mm) between the strut tip and the bottom of a 2x4 put across the fenders. All of the spacers are below the plate (but I have a '98). It should only take one or two test fittings to figure out exactly what you need.
Hope this helps,
Chris
ToplessStang
591
Montreal, Canada
May 15, 2005
  • May 15, 2005
Thanks guys. I ended up installing 1 thin spacer under the plate and 1 thin, 2 thick above the plate. I don't think people will notice the two holes I had to drill on the top of the hood .
Joke of course .
nyuk98gt
1,427
Chesterfield, MO
May 15, 2005
  • May 15, 2005
Cool. Glad to hear it worked out.
Don't forget to take it in for an alignment!
Chris
00redGT
72
Central Ohio
Jun 20, 2005
  • Jun 20, 2005
I know that this is an older thread, but this is exactly what I did...one thin under and the rest on top. I must say that it looks odd having the strut shafte stick that far out of the top of the tower.
I ended up using a aluminum foil ball (instead of putty) to check for hood clearance and everything seemed to be fine.
Now, I need to get an alignment done.
ToplessStang
591
Montreal, Canada
Jun 20, 2005
  • Jun 20, 2005
It may look strange but what a handling diffrence. Let us know how you like the H&R's.
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Saturday at 8:51 AM
Rdub6
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
Saying Hi
  • BriansNSane
  • Dec 20, 2025
  • The Welcome Wagon
The Welcome Wagon Dec 21, 2025
BriansNSane
  • dan50
  • Jul 18, 2026
dan50
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
