  • 1994 - 1995 Specific Tech
MM control arms will they help?
  • Thread starter Thread starter saleener94
  • Start date Start date Jun 3, 2008
saleener94
153
Compton,CA
Jun 3, 2008
  • Jun 3, 2008
Is anyone using Maximummotorsports heavy duty Adjustable rear lower control arms? I want them to prevent my driveshaft from rubbing on the e-brake bracket and cables and I don't mind having the car a little higher from the rear, I think it looks kool. Do you guyz think this mod iz worth it considering i'm mostly stock?
Bosko5.0
1,067
longwood, FL
Jun 4, 2008
  • Jun 4, 2008
DO you still have the bracket that goes ontop of the pinion?
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jun 4, 2008
  • Jun 4, 2008
their def worth it IMO. but a cheaper alternative i seen b4 is little spacers that sit ontop of the spring pearch, or you could get some urethane spring isolators
saleener94
153
Compton,CA
Jun 4, 2008
  • Jun 4, 2008
what pinion? actually i dont mind the price on the LCA's i've seen them for $360, but if itz a good difference in ride height and helpz my rubbing problem i'll definately get them. I've heard alot about polyurethane being noisy when it comes to suspension partz and i'm trying to avoid that.
saleener94
153
Compton,CA
Jun 4, 2008
  • Jun 4, 2008
I just looked up the summit urethane spring isolators from summit will they really lift my car a bit?If it will I could get that instead of the LCA's and spend my money on something better for my stang.
fiveoho
1,958
TN
Jun 5, 2008
  • Jun 5, 2008
what are these? can you give a link
also subscribing. i have the same problem with the rubbing
urban96
3,464
Syracuse, NY
Jun 5, 2008
  • Jun 5, 2008
http://www.need-4-speed.com/kennybrown.htm under springs
saleener94
153
Compton,CA
Jun 5, 2008
  • Jun 5, 2008
I think thats the same as the coil spring set from summit. These are what pops up when you do a search for spacers.
C
CoiledSkunk
  • Jun 6, 2008
When I got an aluminum DS, it rubbed the e-brake cables/bracket. I got the adjustable LCA's for that very purpose. It's okay if the car is empty but if you have people in the back seat, it will rub still. I had to replace the uppers as well to prevent the slop in the pinion angle.
SN95StangMan
1,292
Lynwood, CA
Jun 6, 2008
#10
  • Jun 6, 2008
  • #10
The spring isolators will only lift the car if you dont already have spring isolators on there. Couldnt you just grind off some of the bracket or hit it witha BFH?
saleener94
153
Compton,CA
Jun 6, 2008
#11
  • Jun 6, 2008
  • #11
the stock ones are pretty ripped up and one of them looks like itz almost completely gone so i think it might help. Oh and LCA's will have to wait for now, because I just ordered spring isolators, a VSS, and an edelbrock performer intake. I don't know why I did that. oh well.
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
A
SOLD For Sale: 1993 Ford Mustang Cobra Modified
  • anjteal93
  • Sep 5, 2025
2K
Fox Body Mustangs For Sale (1979-93) Oct 26, 2025
Mindseye007
