MM k-member brace?
01LaserRedCobra
318
Has anyone used one of MM's K-member brace's? I was just curious if it helps, and if you can notice a difference? Or is it a waste of money?
I have there strut tower brace on now, but was wondering about the lower end. There is just a weak looking bar on there now, and figured MM's 4 point brace maybe better?
Thanks,
i also was think of a k member replacement, but for many of them you have to use aftermarkek a arms and coilovers to use the k member. so it winds up costing too muck money. also are coilovers any good? i would not want to use them. anyway im sure you would feel some difference. and you will also cut about 30 pounds off the car with the k member.
im just looking for one that you can use your stock a arms.
Stallion I ended up ordered one and figured it would help more than the 2 point oem brace. It was only $99 so I figured what the hell. I imagine installation is real easy. It just goes into the existing holes correct?
Thanks,
Thanks,
instructions are on the k-member brace page.. forgot if there's 2 holes you have to drill. Let us know results when you get the piece, and if you ended up having to drill or not.. MM makes some nice stuff :nice:
-wade
