  • SN95 4.6L Mustang Tech
Modified Predator Tune Installed
  • Thread starter Thread starter STL00GT
  • Start date Start date Jun 10, 2004
STL00GT
49
Saint Louis
Jun 10, 2004
  • Jun 10, 2004
I just thought I would share my experience thus far with the Diablo Predator Tuner. The unit arrived yesterday and I couldn't wait to turn off my 02 Sensor. The manual should be read before installing any tune but it is really straight forward.
Follow the prompts on the screen to load your original tune in the unit and then you can install the custom tune. I then installed the Performance Tune after modifying a few parameters.
I shut off the 02 sensor by following the directions in the manual. You have to turn off 5 things to get the light off forever.
I then upped the Shift firmness for 1-2 shift and the 2-3 shift. I put both of these values to 50 (max is 130).
I have to say that the car ran good this morning and the 1-2 shift got a good 1 foot chirp. I will play with this a little more but for now I am satisfied. My gears are going in this weekend and I will then correct the ratio to 4.10s.
This is just my personal experience.
DELOS02GT
461
Naperville, IL
Jun 10, 2004
  • Jun 10, 2004
What 5 things did you have to turn off for the O2's? Mine only had 2 things.
STL00GT
49
Saint Louis
Jun 10, 2004
  • Jun 10, 2004
I turned off the following per instructions:
OBDII EGR = Turn EGR on/off, ONLY USE WHEN REMOVING THE EGR
To Set OBD-II setting for no rear 02’s -Turn all of the following parameters to “OFF” position:
OBD-II MIL
OBD-II Test
Heater bank 1 downstream
Heater bank 2 downstream
O2 Sensor Config
You can probably do it another way but I turned all these off. It worked fine and no more check engine light.
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
Fuel 1990 installing edelBrock intake
  • Beaker
  • Oct 5, 2026
Fox 5.0 Mustang Tech Oct 6, 2026
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
