  • 2005 - 2009 Specific Tech
Mods and tuning.
  • Thread starter Thread starter Radman
  • Start date Start date Feb 6, 2007
Radman
113
Texas
Feb 6, 2007
  • Feb 6, 2007
Do I need to change tune after installing under drive pullies or 4.10 gears?
Speaking of pullies...anyone experience any issues with under drive systems?
red05bullitgt
861
Pittsburgh, PA.
Feb 6, 2007
  • Feb 6, 2007
Not for underdrive pulleys, but you definitely must reflash your tune whenever you're changing gears..
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Feb 6, 2007
  • Feb 6, 2007
for the gears, you will need to adjust the ratio in your tuner, nothing else.
no tune is needed with the pullies, and i have not experienced any problems yet with them.
XStanger
383
  • Feb 7, 2007
No probs with any of the underdrives here either.
P
Pro Mod
236
Wharton, WV
Feb 7, 2007
  • Feb 7, 2007
SOMETIMES, although a very rare occasion, some drive-by-wire settings must be changed in the tune for the 4.10's. My car happened to be one of those rare occasions. This just goes to show how all cars are different, and not all ecu's function EXACTLY the same. You MOST LIKELY won't have to worry about this problem, but nonetheless here is a heads-up that this complication IS out there just in case it happens to you.
Apparently, the Spanish Oak & the drive by wire system closely matches rpms vs. vehicle speed... it seems some ecu's more aggresively than others. When I installed my 4.10's, I flashed my tune to fix the speedo. Quite often I would then get "the wrench of death" when I went to WOT at certain speeds. Evidently, the drive by wire system was seeing that my rpm's no longer matched OEM vehicle speed. If I reflashed my ecu back to having stock gears, I no longer got "the wrench of death." In reality, my speedo was now off; but as far as the ecu was concerned, my rpm's were now matching vehicle speed.
My solution was to get a new tune that would not only change the speedo for 4.10's, but also changed some drive by wire settings for the 4.10's as well. After I got my updated tune, all is well. Evidently, my ecu compares rpm/speed/load very aggressively.
kooldawg6
mine works really well and can take a fair amount
Aug 31, 2006
1,679
Central VA
Feb 7, 2007
  • Feb 7, 2007
I'm guessing you could kind of change the car's tune for the pully swap. You can change the rpm your car idles at for instance. Would that be of any benefit at all?
M
4.10 gears = 200,000 miles ?
  • michaelleewebb
  • Apr 1, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 2, 2026
michaelleewebb
M
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
F
Help with air bag code 2293
  • Felwinters
  • Apr 23, 2026
2005 - 2009 Specific Tech Apr 23, 2026
Felwinters
F
