  • 2.3L (N/A & Turbo) Tech
MOds Begin?
  • Thread starter Thread starter JohnnyMustang88
  • Start date Start date Aug 17, 2004
J
JohnnyMustang88
22
  • Aug 17, 2004
So I just bought a 1988 Mustang LX 2.3L. Thing is in bad bad shape, but it was 200 bucks and runs. Good gas mileage and all that. My first question is, I need more than 90 HP. What's the first thigns i should do? Besides an engine swap. Which I will go to 2.3L Turbo by next year. ANy ideas? I'll take some pictures if people wanna see it.
Sims6986
50
Indy
Aug 17, 2004
  • Aug 17, 2004
Intake, Exhaust, ranger roller cam, ported & polished head and a ranger header. That would be about all i would do if you are planning on doing the 2.3t swap. No point spending a lot of money on N/A mods, when you can save it for a bigger turbo, injectors, and other goodies .
J
JohnnyMustang88
22
  • Aug 17, 2004
ranger roller cam? rangers came with 2.3's? Maybe i won't do anything and save my money for a 2.3t engine and turbo and everything. then rebuild the engine and install it... What cars where the 2.3t's in?
Sims6986
50
Indy
Aug 17, 2004
  • Aug 17, 2004
It would be cheaper to do. I've heard of people only spending a couple hundred bucks for turbo motors.
J
JohnnyMustang88
22
  • Aug 17, 2004
ya there's two on ebay right now for ~800. Was just thinking in the meantime. My car is real rough. I guess I'll make it look good while i save the money up for the turbo and engine. Right now Im making the power locks work again, The actuators were froze and the wire that carries power from the battery to the locks was shorted to ground, adapting my 91 explorer actuators to work in the mustangs doors. so far i got one done just need to mount it then the other one will be easy too.
Shawneebear93
20+ Year Stangneter
May 4, 2004
518
17
49
Salisbury Twp, Allentown, PA
Aug 17, 2004
  • Aug 17, 2004
2.3T's came in Thunderbird Turbocoupes, Mercury XR4TI's, and a few more I'm not sure of.
Don't take the turbo engine out of an SVO or and 83/84 GT Turbo or 84 Anniv. model because they're very rare.
TurboFlush
1,984
Germany
Aug 17, 2004
  • Aug 17, 2004
Only thing I will say is be carefull as the parts are getting hard to come by. as you can see by this forum there is alot of suport for these motors. and this is only a small part of what is out there. Originall swaps are becoming harder to find. Either the Turbo cars have been striped of their parts and crushed. or been restored and garaged for the rest of time.
Not to scare yah away, but good things dont always last so long. you might have to end up using a N/a block and building the setup from scratch. (not impossible, I am doing it on a 2.0). good thing is the market for aftermarket goodies has grown aot in the last many years.
have fun, be safe.
J
JohnnyMustang88
22
  • Aug 17, 2004
I'm not to worried about having to use a N/A block. I can find those pretty cheap and change the internals, I can also mix and match if need be. It'd be nice to have a donor car tho.
JamesBaumann
624
Vancouver Island
Aug 18, 2004
  • Aug 18, 2004
If you search through the tech articles you will find a how to on building a CAI. It is always a good first performance mod. You can also look at advancing your timing a few degress, it should give you a little more power. If you plan to swap to a 2.3T then in my opinion you should be more concerned about working out all the cosmetics of the car and working out all the mechanical bugs first. Maybe do some exterior work or something. I wouldn't spend too much on adding power to this motor you have now. However, a CAI can easily be swapped onto a turbo motor, so you could go ahead with that. Timing advance is easy and free. The best power is free power. I would recommend doing your exhaust after the turbo swap because you are going to want full 3" exhaust and that is way too big to have on a naturally aspirated car. Search through the tech articles, there are many little tricks you can do in the meantime. By the way, is it an automatic transmission or a 5 speed manual?
J
JohnnyMustang88
22
#10
  • Aug 18, 2004
  • #10
Thankfully it's a manual. I like the car and am going to be happy with it. Unfortunatly i'll have to do cheap exhaust for now. the cat are plugged and the pipes have holes in them. Otherwise You're probably right. I just don't know much about exterior stuff. I'm working on the interior now. It's a big job because half the power wires to things are shorted. Just fixed my power locks, adapted my old explorers lock actuators into the mustang and ran a new power wire. Now i have to figure out my hatch and why it won't pop. Then i need a new center console. and new seats and new carpets and new dash. heh pretty much a whole new inside...
JamesBaumann
624
Vancouver Island
Aug 18, 2004
#11
  • Aug 18, 2004
  • #11
Sounds like a lot of work. That should keep your time occupied and your wallet empty for a while.
J
JohnnyMustang88
22
#12
  • Aug 19, 2004
  • #12
Ya. If I even bother. Maybe I should just buy one thats already in good shape.
TurboFlush
1,984
Germany
Aug 19, 2004
#13
  • Aug 19, 2004
  • #13
nah, just fix that one.
that is part of the fun.
you get a special bond when you know how to take everything in and on the car apart.
Just do what you can with what you can.
You will find deals as time goes. I did. My car wasnt in the best of shape when I first bought it. The motor was not runnign and the interior needed some love. The paint still needs love, but I dont know what I want to do with it still.
Today it sits on blocks in a garage awaiting my return.
Opinions on a possible project car w/ pics
  • Teen'93stang5.0
  • Mar 29, 2026
2.3L (N/A & Turbo) Tech Mar 30, 2026
Teen'93stang5.0
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
