  • SN95 4.6L Mustang Tech
modular?
  • Thread starter Thread starter Blownstang450
  • Start date Start date Jun 23, 2004
Blownstang450
  • Jun 23, 2004
hey guys im a newbie and ive been reading up on mustangs for quite some time...my brother had an 02 GT and an 03 Cobra and he is the one who got me hooked on mustangs...anyways i always click on the Modular 4.6 forum and i just want to know what is 'Modular' referring to?
Modular2v
3,222
23
99
oklahoma
Jun 23, 2004
  • Jun 23, 2004
Most of the time the modular is reffering to "interchanging parts" for example the 4.6 is interchangable with the 5.4 ex: HEADS, bearings etc....
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jun 24, 2004
  • Jun 24, 2004
ya, there are a lot of parts that are interchangable. heads, cranks, rods, pistons, can be interchanged within the years.
BLK_ROUSH
1,300
Newnan, GA
Jun 24, 2004
  • Jun 24, 2004
And even platforms .... Explorer, Aviaitor, Mark VII
Welcome. Hope we can answer your questions, and represent the best side of the Mustang family.
Modular2v
3,222
23
99
oklahoma
Jun 28, 2004
  • Jun 28, 2004
werent some of the parts on the 5.0/5.8 interchangable also?
mogs01gt
3,113
30
119
Ohio
Jun 28, 2004
  • Jun 28, 2004
Yes you could swap the heads out on the Windsor 351 motors.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jun 28, 2004
  • Jun 28, 2004
american manufacturers like the modular idea when it comes to engines. ford has their modular 4.6/5.4/8.6, and the windsor family 260/289/302/351W, plus the FE's and the big blocks. chevy has the 327/350 and the 454. it makes everything cheaper to manufacture when the same basic architecture is used on on their motors. the cool thing about the ford modular motors is that you have both sohc and dohc head options as well as iron and aluminum blocks.
Skud
493
Saskatchewan
Jun 28, 2004
  • Jun 28, 2004
I think the term "modular" referrs to how each cylinder in the block is "self-contained" so to speak. Each cylinder has it's own oiling, cooling system and allows for cylinders to be added/subtracted without re-designing the whole engine. You can get different engine configurations just by adding/removing cylinders.
That's what they did with the (newer) BOSS 351. It's essentially a "cut-and-paste" engine. It's identical to a 4.6 modular just with 2 cylinders pasted in the back. Same with the heads, crank, etc...
Riley
Modular2v
3,222
23
99
oklahoma
Jun 28, 2004
  • Jun 28, 2004
skud that could also be used as the definition, good point!!! At first when i saw the boss 351 i thought they were referring to the v10 used in the trucks with customized DOHC heads! i later read it to find out that it was a 4.6 with 2 cylinders pasted on and 4.6 dohc heads that were also customized for 2 more cylinders! I kind of felt stupid even thinking it was the v10 (6.8L) used in the trucks because a 351 would be equivalant to a 5.8
J
jbrown
393
Tallahassee, FL
Jun 28, 2004
#10
  • Jun 28, 2004
  • #10
I believe chevys 350 is not a modular engine it is a pushrod engine.
PULMEOVR
I need a bigger E-Penis.
Sep 29, 2003
560
Ottawa, Ontario Canada
Jun 28, 2004
#11
  • Jun 28, 2004
  • #11
He was just saying the Chevy 327/350 and the 454 have the same basic architecture.
smokin'Red35th
493
Las Vegas, NV
Jun 29, 2004
#12
  • Jun 29, 2004
  • #12
not to hijack, but can someone explain the difference between modular and pushrod in definition. I know very little about the pushrod engine and still relatively little about the modular. Could someone shed some light on this for me?
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jun 29, 2004
#13
  • Jun 29, 2004
  • #13
pushrod engines have the camshaft in the block. the camshaft pushes on a pushrod, which pushed on a rocker arm which opens the valve. its a really good design for compactness. 99.9% of the pushrod motors are 2v. the modular motor is fords foray into ohc motors. the cam is moved to the heads and there are wither 2 or 4 cams. modular is just what ford called its ohc v8's and v10's. ohc motors are usually more complicated to manufacture and assemble and in turn cost more. the ohc v8's are physically bigger than their pushrod counterparts, even with smaller cubic inch displacement. if you've seen a bare 4.6 block you would know its rather small, but the heads are big. the SOHC heads are closer to a more normal pushrod head, however the DOHC heads are really rather large.
smokin'Red35th
493
Las Vegas, NV
Jun 29, 2004
#14
  • Jun 29, 2004
  • #14
thanks bdcardinal, thats exactly what i was looking for
enyawix
507
Jun 27, 2006
#15
  • Jun 27, 2006
  • #15
Was a ford DOHC v10 ever made?
T
thomas91169
I'd donkey punch my sister.
Aug 19, 2005
Modesto, CA
Jun 27, 2006
#16
  • Jun 27, 2006
  • #16
modular is just refferring to how ford can design motors to be interchangeable.
pushrod is refferring to a motor where pushrods are the part between the cam and the head, the cam is in the block valley and the pushrods rest on the lobes which transmit their force up into the head which presses on the rockers. most manufacturers have switched to OHC(over-head cam) in which the cam directly contacts the rockers.
helty
some Ukrainian's enjoying a handjob via my credit
Mar 30, 2005
1,461
Baltimore, MD
Jun 27, 2006
#17
  • Jun 27, 2006
  • #17
doesnt it also have something to do with the way the tooling can be quickly changed out at the manufacturing plant to produce a 4.6 or 5.4? Did I read that somewhere or am I smoking crack?
jasonh_86
I
May 20, 2005
1,156
Arkansas
Jun 27, 2006
#18
  • Jun 27, 2006
  • #18
You're probably smoking crack.. damn hippies
Skud
493
Saskatchewan
Jun 27, 2006
#19
  • Jun 27, 2006
  • #19
Indeed it was.. In limited numbers.. Here is a quote from Motortrend:
If you do the math, this all-aluminum, DOHC V-10 based on the current Modular 4.6 comes out to be just a smidgen under 351 cubic inches. That's why this silver rocket-launcher proudly and appropriately wears Boss 351 decals in the best '71 Mustang tradition. On a chassis dynamometer, its clandestine motor is said to deliver 430 horsepower and 405 lb-ft of torque to the rear wheels.
and here is the link... http://www.motortrend.com/roadtests/coupe/112_0308_ford_mustang_boss_350_v_10/
Riley
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
