It has no over drive... ERR!!! Before they go running off to the shop with it I figured you guys might know what they will sell or have a suggestion... It has 126,000 miles... Fluid is dark! I drove it and if u start out with the shifter in O/D and go as soon as it shifts into the final gear it is like its in neutral no pull but if you drive with it in D perfect... Jus wanted to get your guys views... Im stumped on this one... I was thinking drain the fluid and put new fliter and so forth in it or maybe there is a linkage messed up...
