TorqueyFox
San Diego
What's up guys, I'm new to the forum so sorry if I sound like a noob lol anyways so I've been searching all over the web for my problem but i keep getting stumped. I have a 1990 5.0 hatchback, ever since I bought the car it will not turn on after driving it for a bit, or if it gets warm. I've already replaced the TFI module and still same problem. It is getting spark, ignition coil is fine. I don't think my starter is getting heat soaked because the car cranks and all. Not too long ago I had an issue with the car bogging out at WOT and going up hills. I took it to a guy and it ended up being the fuel pump. The funny thing is, that the guy said he had put another ECU in it and it would turn on hot, warm, cold, whenever. He had put an A9P though and my car is a 5speed so it has an A9L. But anyways could the ECU be my problem? I just wanna gather more info before I start spending any cash on replacement parts. Idk if my mods would be helpful to throw out there but here ya go: 24lb injectors, Perfromer rpm 2 intake, bbk cai, 70mm tb, bbk shorty headers, off road x pipe, flowmaster 40s, SCT 4 Bank Eliminator Switch Chip(everything is tuned accordingly except injectors), battery relocated to trunk, subframe connectors, msd ignition coil, ford racing plug wires, shorts shifter, 3:55 gears. Another thing is that if I let cool down for let's say 15 minutes it'll start up but pretty weak. But if I start her up after about two hours she'll start perfectly fine. Well that's that hope you guys can help me out with this problem because it kinda sucks having to explain to people why we have to let my car cool down before going anywhere else also been having this car for about 8 months now so I think it's about time I get to the bottom of this. Oh yeah and I can't pull any codes because previous owners messed with the diagnostic port, wires are cut. Thanks in advance guys!
When you say 'turn on' do you mean start up, motor cranking but it does not start up or your engine will not turn over with key in start position.
Look for a sticky thing by jrichker
Cranks but no start or no crank thingy in the sticky section
Tell him I sent you, I need some brownie points
Yessir that's what I was trying to say
If you have the injectors lying around, it'll be free to find out.
Under normal circumstances, putting 24s into an otherwise stock setup will make it run rich but not crazy rich.
That aside, who knows how it was tuned for the other mods before the 24s were put in. The old tune might have run ok but now the conditions have been changed. That change can land you in the situation you're having.
So if I"m understanding what you're saying, the car has never been tuned for 24 lb injectors.
If that's true, put your 19 lb. injectors back in and your hot-hard-start, will likely disappear.
But what would that have to do with it not starting when warm? If that was the case wouldn't I have a hard time starting her up whether cold or hot? It starts up immediately when cold
Not necessarily. There are multiple ways to bring the Air Fuel Ratio into the sweet spot. You can increase timing and gas, lean timing and gas, etc., and so on.
If we assume for a moment that fuel was enriched and AFR brought down by other means, then you have a setup that was tuned to give the injectors a high pulse-width in order to dump a lot of fuel. Now on-top of that, you've tossed in a larger injector. The EEC has no idea that this has been done and will deliver the same pulse-width to the 24 lb injector that was meant for the 19. Not so good.
Additionally, you could also have one or more leaking injectors. That also causes a very hard-start-when-warm condition for the same reason that a larger than required injector would.
Several things change from cold to hot engines, as stated above concerning the 24 pounders, cold start maybe good because plugs have strong spark to handle the extra fuel, an engine that is at operating temp when shut off will experience heat soak, spark maybe weaker when in this heat soak situation and may not be able to 'light the fire' so to speak.
Make sure you have a good ignition path, plugs, wires, cap and rotor, put some 19 pounders in there and see what happens.
Reactions: TorqueyFox
Engine does crank but will not fire up
When it won't start, do the checklist...
Cranks OK, but No Start Checklist for Fuel Injected 5.0 Mustangs model years 1986-1995
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 15-Sep-2014 to add temporarily bypassing the MSD box if it is present.
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD, Crane, or other ignition box if present - Bypass it and return to stock configuration if possible. Do this as a temporary measure to eliminate it as a possible problem source.
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No EEC or computer power - EEC or computer relay failure
86-93 models only: EEC relay next to computer - look for 12 volts at the fuel injector red wires.
Both 86-93 and 94-95 models: No 12 volts with the ignition switch in the run position on the fuel injector red wires. The relay has failed or there is no power coming from the ignition switch. Make sure that there is 12 volts on the red/green wire on the coil before replacing the relay.
F.) No EEC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
94-95 models only: Check inside fuse panel for fuse #18 blown – 20 amp [fuse
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer. Don’t replace the computer just because you don’t understand how it works. Computers seldom fail, it usually is a sensor or wiring problem that causes the problems.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red/blue wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 2-4 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
B.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
C.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
See the graphic for the 10 pin connector circuit layout.
The injector power pin is the VPWR pin in the black 10 pin connector.
D.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the EEC relay and the red wire for the 10 pin connectors.
E.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it, if you get this far. If it starts, replace the ECT.
Next time you try to restart it warm, press the gas pedal to the floor. This signals the ecu to not fire the injectors while cranking. If it fires up then, you are likely rich.
Injectors would be #1 suspect, but so is a faulty ect sensor. Have you dumped codes?
