MOnte Carlo bar ?
65 A Code said:
I am guessing what air cleaner you have would determine if you get the straight or the "bow" in the middle type? IF that is not correct what does determine it?
Thanks
You are correct, the air cleaner you run determines the bar needed. My dual quad setup and my Webber setup both require a bar with a "bow" or curved section in order to clear the air cleaner/carb bodies.
Thanks
I was under the impression that the type of distributor you have also played a role in determining if you need a straight or curved bar, am i wrong?
I don't know myself, though I'd say the difference in strength between curved and straight is so negligible (unless maybe you're autocrossing or something like that) that I would just get the curved and be done with it. But, that's my opinion.
I would think that it will fit that combination, but like I said, I don't know for sure.
