more hp with pi head swap than just stock pi's
The Ford Racing catalog says it will bump your compression ratio to 10:1 from 9:1 (I think). This is because the non PI motors have flat top pistons where the 99+ motors have dished pistons. Like others have said, boost is not recommended with this increased compression. I've heard that nitrous loves compression, though.. so I'll let someone more knowledgable than I comment on that.
hotmustang331 said:
What I have heard is that they get around 285 HP after the swap....
We only wish those numbers could be reached. The average HP after a swap that I have seen was between 245 and 260. You also have to factor in other mods as well. The swap with non ported PI heads will give you about 40 - 50 more HP. These are actual numbers from Dyno sheets that have been posted. You may have a factory freak push a few more ponies but nothing close to 285. Once again you also have to factor in other mods such as cams, headers TA and of course a good tune.
I ended up with 249 hp three pull average at the rear wheels after the headswap. Mine prefers 93 octane gas too. The hp/tq didn't really come alive until after the chip was custom burned with all the bolt-ons and other "tweaks" done to it. It's worth the money, especially if you take the time and do it yourself. It's not that difficult, just time consuming.
pi headswap
Hey,my boyfreind is in the garage doing the complete pi swap to my car right now.Except without the pi cams.We are using 270's.He should be done around 5 or 6 tonight.I will tell you guys how much of a difference it made.
tomustang said:
Parkway performance claims 60+ hp gain... but ill find out soon, just finished the swap. the compression ratio will also rise to 10:1 - 10:5.
Did you get the head swap kit from Parkway? Thats where I bought mine, I'm going to start the swap on Monday, when I get off work. Nice kit!! Looks very complete, all Ford parts, even the sparkplugs.
