  • 1994 - 1995 Specific Tech
More Problems
  • Thread starter Thread starter Nagash01WS6
  • Start date Start date Mar 27, 2004
N
Nagash01WS6
402
Deland, FL
Mar 27, 2004
  • Mar 27, 2004
Well... it just keeps going with this car....
Replaced the rear brakes today... passenger side pad was grinding against the rotor. So we got a set of rear brakes rotor / pads each side. Well... drivers side slide pin was seized in the caliper mount. Got that free with the help of acetlyne and a pipe wrench. Picked up the new slide pins / brake hardware kit at autozone... went back and put it all together. Went to fix a leaky front caliper... and made it worse. Another trip to autzone and took care of that.
So... I drive it about 4 miles home. Stop... get a nice whiff of brake. Didnt see any smoke... figured it was the new ones breaking in. Pull into the driveway... and the rear passenger side is smoking. Great.
The entire time... the car was running like crap. It stalled twice without my help on the clutch. It wasnt throwing any codes though. Just replaced cap / rotor / wires / plugs in order to fix a misfire problem... which it didnt at all. Car still misfires about a minute after startup.
So... any ideas on whats up with the brake or the motor???
Car started throwing codes when I missed a shift and nailed the rev limiter rather well. Next day it started runnin like crap.
jmuva44
1,338
Richmond, VA
Mar 28, 2004
  • Mar 28, 2004
wow...that doesnt sound like fun. Maybe you should keep the WS6 and sell the stang! lol I think I probably would anyway just cuz those TAs are bad. You should get a buddy or someone to put another set of eyes/ears on your car. Especially someone that knows mustangs. I mean you could find the answer here if you try hard enuf but its hard sometimes to properly explain this kind of stuff online and you sound to have some fairly unusual problems. Your rear brake sounds maybe like a piston is stuck or something. Thats my first guess.
Your car misfiring could be timing, ECT/ACT sensor, or really any number of things. Thats a tough one. Just keep askign questions online and to people you know and do extensive word searches on stangnet and corral (others may have had the same problems as you at some point). Good luck to you! In the meantime, I gotta fix my idle problem, high temp problem and rattle from underneath my car. What fun.
Y
yellow1995Cobra
2,959
Massachusetts
Mar 28, 2004
  • Mar 28, 2004
I had a miss like you said once. It would only do it when the car was ran for a minute or two. Ended up being the distributer, after replaceing every other possible iginition component. Sucks chasing problems like that.
Good luck with the car. I think you should have gave it a more thorough look over before you bought it.
RIO5.0
6,892
N.H.
Mar 28, 2004
  • Mar 28, 2004
Sounds like the caliper is seized or the Ebrake is out of adjustment??? You replaced the caliper? correct?? Did the rotor spin freely after re-assy??
N
Nagash01WS6
402
Deland, FL
Mar 28, 2004
  • Mar 28, 2004
Nope... didnt replace the caliper.
The piston went back into the caliper fine.
I guess we'll try replacing the caliper today.
As far as the ignition... it started after I misshifted... stuffed it between 1 and 3 and smacked the rev limiter REAL good.
mto502
357
Ancaster, Ontario
Mar 28, 2004
  • Mar 28, 2004
I f you hit the rev limiter that good I hope you didn't cause internal damage. Was this on a downshift ?
I'm thinking rods here.
50_Dave
68
  • Mar 28, 2004
kyle you dork.
Take a voltage reader and check to see if are getting voltage to all 8 injectors. Next (and i have the tool for this so you can come to my house and do it) take the spark plugs wires off and see if they are getting spark. You should be able to tell then if you are getting spark from the distributor or if its past there. Remember all those problems i had with mine misfiring? We will get it taken care of, just have patience man.
I have wednesday off from work, and plan on changing the header gasket on the passenger side, so if you want to come over then, ill be wrenching it up and we can work on your car as well.
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
Mar 28, 2004
  • Mar 28, 2004
Where did you get that from? My dad says my car is missfiring so I guess I need to check that out.
50_Dave
68
  • Mar 28, 2004
I got it from some autozone/discount auto place.
You take the wires off from the plugs. This tool/tester connects to the plug wire while the car is running and shows you if you have spark going through it.
N
Nagash01WS6
402
Deland, FL
Mar 28, 2004
#10
  • Mar 28, 2004
  • #10
No... upshift... went between 1st and third and I punched the gas.
doh.
Im thinking a pushrod or two myself...
331 cobra
398
Silicon Valley CA
Mar 28, 2004
#11
  • Mar 28, 2004
  • #11
The 302 bottom end shouldn't care about 7-8,000 rpm if there isn't any load, like a missed shift, if your valves floated enough, you could have smacked one with a piston. I would try a leak down test, if all of the cylinders are good, you will have to look at the ignition and the pushrods. This might be a great time for you to add a Tmoss ported lower or an Explorer if you are going to pull the intake any way.
Good luck
N
Nagash01WS6
402
Deland, FL
Mar 28, 2004
#12
  • Mar 28, 2004
  • #12
Only thing is I dont hear any ticking or any firing out of the intake like with a bent pushrod or bent valve.
It BOUNCED off the rev limiter... thats about it. Then it threw some codes.
Next day is when the ignition started going nuts. Its either throwing a code 17, 27, or 72... i dunno which... the flashing code thing escpaed me today.
50_Dave
68
#13
  • Mar 29, 2004
  • #13
Get off your fat ass and come to orlando shrek. We will get that thing running right if it kills me.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Mar 29, 2004
#14
  • Mar 29, 2004
  • #14
The codes for our cars are ALL 3 digits. No 2 digit codes. Here is a link to the list of the codes. Also, the computer repeats the codes, so you should see each code twice.
http://www.allfordmustangs.com/Detailed/445.shtml
Post back when you successfully run the codes!
I don't know of any code regarding "hitting the rev limiter"....It just may have been a coincidence. If you did bust a valve, a compression test would eliminate that problem.
Scott
Scott
N
Nagash01WS6
402
Deland, FL
Mar 29, 2004
#15
  • Mar 29, 2004
  • #15
I seriously doubt its a valve.
On another note... the damn rotor / pads were really toasty last night after driving on the pass. side. I guess I need to check out the e brake thing...
N
Nagash01WS6
402
Deland, FL
Mar 29, 2004
#16
  • Mar 29, 2004
  • #16
Found the brake problem... seized slide pin.
Loosened up the caliper and it popped right off... so I knew it wasnt seized up.
Checked the slide pins... and one is seized out pretty far.
50_Dave
68
#17
  • Mar 30, 2004
  • #17
shrek...
N
Nagash01WS6
402
Deland, FL
Mar 30, 2004
#18
  • Mar 30, 2004
  • #18
50_Dave said:
shrek...
Why you gotta be callin me shrek...
I need to figure out teh misfire problem.
Gonna pull the code(s) today.
Going to replace the PCV and Fuel Filter today also.
And thursday... battery / battery cables.
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
  • Gulftown980x
  • Jul 29, 2026
squeak93
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
