More Problems
  • Thread starter Thread starter Funhog
  • Start date Start date Apr 15, 2005
Funhog
219
Alabama
Apr 15, 2005
  • Apr 15, 2005
I got my car started after 4 days of having it sit in Bethlehem since it wouldnt start. I know I need a new starter. Does anyone know of a good brand for a 92 LX? So now that it is starting, the voltage on the battery fluctuates like crazy when I start it up and leave it in park. This morning when I started it to go to PT, the interior lights were dimming and it just sounded awful, like it was dying. Do I now need a new battery? I was planning on putting march U/D pulleys on and leaving the stock alternator pulley on, but now I am scared to even put any pulleys on. Any thoughts??? Thanks
Ryan
gregpro50
140
Binghamton NY
Apr 15, 2005
  • Apr 15, 2005
'92s used the high torque mini starters. I dont really think that one is better than the other as long as it works. The problem you are having sounds like a charging problem more than anything. Prolly needs to have the alternator replaced. Pullys will work fine as long as everything else is working OK.
vristang
4,933
101
124
Seattle
Apr 15, 2005
  • Apr 15, 2005
Probably some haywire e- stuff.
First check the grounds and Alt cables. Once these wires corrode your screwed. Hope that its the cables, cause thats probably the cheapest fix.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 16, 2005
  • Apr 16, 2005
Excellent advice...
The secondary power ground is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges. Any car that has a 3G alternator needs a 4 gauge ground wire running from the block to the chassis ground where the battery pigtail ground connects.
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
C
Stock 1993 charging issue at idle
  • Charlie1
  • Sep 21, 2025
Fox 5.0 Mustang Tech Sep 24, 2025
Mustang5L5
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
  • brandyn200
  • Jun 20, 2026
AeroCoupe
