Ok guys... Lot of headway... lots of questions.
#1. While idling the temp gets HOT 225-230ish so we shut it down. After letting it cool down we took it for a drive to see if it did the same with air flow... Yup... had to shut it down again and let it cool. The top hose is hard and has pressure, fan is running but its blowing cold air away not hot... poped the upper hose and there is no coolant in it... any ideas???
My thoughts:
A. T stat in wrong- What side faces the motor???
B. Needs burping - If you think so whats the best way???
C. Water pump issue
#2. We have bled the brakes quite a few times and the fluid is coming out nice and clean however, the brakes when driving are spongy and the pedal does not come back up right away. Do you think this is a bleeding issue??? or Vac issue??? any other opinions???
Mods to brake system:
All new lines
ABS to NON ABS
Line lock
SS lines
fluid bleeds on all lines good.
#3. Idles lean see video, its a 24lb cal'd pro M maf. My QH is out for updates and should be back soon:
http://s28.photobucket.com/albums/c236/blindfoldedhope/?action=view¤t=DSCF1154.mp4
#4 After driving the one time the brakelites/interior lite/ autometer gauges do not lite up.... Blown fuse maybe????
The first 2 are major issues that i want to tackle tomorrow! Thanks again guys.
My thoughts:
C. Water pump issue
All new lines
ABS to NON ABS
Line lock
SS lines
