more then one thing wrong this time
  • Thread starter Thread starter Compton_Rider
  • Start date Start date Jul 29, 2004
Compton_Rider
34
  • Jul 29, 2004
ok..i have the same problems as wrathchild but my car is an auto..and it only vibrates at the top of each gear
also..there is oil leaking from my engine..my uncle saw it comming from the front and rear main seal..but my oil was over-ful..so we emptyd about half a quart..and it didnt leak from the seals..but still seemd like it was leaking from the valve covers. how i can tell its leaking is there is smoke billowing from under the hood aruond the headers/cat/valve covers/dipstick (inside)
also..if my main seals are leaking, what should i also replace? its a 5liter 302
also..would any of u guys be willing to pull the engine if it is the seals and maybe help do some bodywork? im in nothern michigan
Mavrick
2,264
Collingwood, ON
Jul 29, 2004
  • Jul 29, 2004
The blue smoke from under the hood is most likely oil leaking from your valve cover gaskets, and dripping down onto your headers and burning off.
Compton_Rider
34
  • Jul 29, 2004
alright..but when i put more oil in (lost half a quart driving 3 hours at 65mph) it wasnt smoking when it was at low but when i put another quart in it was at full..and when i got home (15 minutes drive) it was billowing again..its alot more then just the valve covers..but im not shure if the main seals are also the problem
HISSIN50
34
129
Jul 29, 2004
  • Jul 29, 2004
i would clean it all up really well and run it and watch for new trails. fluids can run all over, making it difficult to pin point (ie a valve cover leak can appear to be a rear main, etc).
that is what i would do. good luck.
88stangmangt
2,332
Stafford,VA
Jul 29, 2004
  • Jul 29, 2004
if it is your main seals you dont have to pull the motor just lift it a little. valve covers seals are easy to re-place.... your either leaking or burning it. they make a dye you can put in your oil that is black light sensitive so when it leaks you know from where might want to look into that.
Compton_Rider
34
  • Jul 29, 2004
how would i solve burning the oil? cuz thats what it smells/looks like
Compton_Rider
34
  • Jul 29, 2004
im going to power wash that entire side of the engine to see where its leaking from also..but burning oil sounds really bad
HISSIN50
34
129
Jul 29, 2004
  • Jul 29, 2004
a wet and dry compression test or leakdown test can help pinpoint it. these motors do burn some.
good luck
Compton_Rider
34
  • Jul 29, 2004
do they burn it enough for a cloud of smoke to come out of the oil filler tube?
is their a way i can reduce the burning oil..i really dont like when i stop at a light and smoke pours out from under my car..
oh yea..when i went to mcdonnalds, stopped to order, and the entire drivers side..even to the rear was smoking..gah
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
Engine Gas in my oil
  • limp
  • Jun 15, 2025
2K
Fox 5.0 Mustang Tech May 16, 2026
Mindseye007
G
4.6L rods and piston into a 5.4L
  • Green mustang
  • Jun 11, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 11, 2025
Green mustang
G
