More vids of the Dynomax (WOT etc)
merc123
420
North GA
jadesville said:
cool vids, you need some better camera placements though :)
I only have 2 hands :) I was by myself. These were more for audio, not visual. One was on top of the mirror and the othe was on top of the passenger side seat being held in place by the headrest.
bemol said:
Sounds good! do you noticed a hp gains with the mufflers?
Cheers
Dan
i know you're not asking me but i did. Previously, i had MRT off road pipe with flowmasters. I switched the mufflers to the dynomax super turbos and gained few after 4k. Little loss in torque but the HP gains up top conpensates. Lot quieter if i may add.
how TF were you shifting.
Car sounds good. I remember the good old days when I used to get traction in first, and second :(
Cheers
Dan
It did actually. Down low and up high. I'm thinking the reason that Kappaball lost some on the low end is because of the MRT off-road pipe. I still have the factory H. Because of his O/R pipe it forces less backpressure restriction which helps with low end TQ. With the factory H, I still have quite a bit of restriction. Also, the OEM pipes have around 250 CFM of flow. The Super Turbo's have 467CFM and Ultra Flo's have something around 800+ CFM. The Ultra Flo's will have too much flow for low end TQ but will have massive upper RPM HP.
I wasn't holding the camera :) I wedged it under the passenger side headrest on the pulling out video (sounds sick don't it) and had it wedged between the mirror and the roof on the van passing video.
