most possible HP on stock heads...
  • Thread starter Thread starter 90mustangfan
  • Start date Start date Dec 7, 2007
90mustangfan
93
So cal
Dec 7, 2007
  • Dec 7, 2007
what the most RWHP you can get out of a stock stroke, 302-306, with all the bolt-ons on stock heads/Cam, No porting/poshishing, No Nitrous,No Turbo, No superchargers, No Strokers, No short belts, no deleting smog, EGR and it must be streetable and pass smog. (Blot-ons are things like, Intake manifold, Headers, H-pipe, Adv timming, MAF, TB's, Roller Rockers, Pulleys, electric W/P's, Lighter Flywheel, Ect.)
Ike83
St. Louis, Missouri
Dec 7, 2007
  • Dec 7, 2007
Fuzion
81
Virginia
Dec 7, 2007
  • Dec 7, 2007
My experiance, with an after market intake, maf, and o/r exhaust.
230-240 rwhp
91 HATCH
Banned
May 17, 2007
262
illinois
Dec 7, 2007
  • Dec 7, 2007
Ike83 said:
7,244
+1 give or take a few based on brand of bolt ons
Ike83
St. Louis, Missouri
Dec 7, 2007
  • Dec 7, 2007
Well......you know.....MOST of the hp comes from the NOS stickers anyway.
Flavadave4
1,044
21
49
Utica, NY
Dec 7, 2007
  • Dec 7, 2007
If i had to guess it would probably be somewhere between 210 and 220 at the wheels.
Modular2v
3,222
23
99
oklahoma
Dec 7, 2007
  • Dec 7, 2007
i have seen an e7 headed car make 242 to the ground with untouched heads!
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Dec 7, 2007
  • Dec 7, 2007
There's a massive difference when you include "306" because that opens the doors to lots of compression and all the cam lift you want (even though at some point it'll be wasted on stock heads). On a stock bottom end, i couldn't imagine more than 230hp max, but with higher compression, a custom cam, race gas and everything else, who knows. Maybe 7,244hp
cervinistang
11
Dearborn, Michigan
Dec 7, 2007
  • Dec 7, 2007
230 max? doesent the stock fox have 220-225?
i can spend a couple G'S and get 5-10 horses!?
Fuzion
81
Virginia
Dec 7, 2007
#10
  • Dec 7, 2007
  • #10
the 225hp stock is at the flywheel.
ninety15.0
1,336
#11
  • Dec 7, 2007
  • #11
i would say that if you are using the stock bottom end and stock heads and cam...you will likely max out around 240rwhp. This is assuming the heads are untouched. With some porting, gasketmatching, some milling and a good valve job i would bump that up to about 260rwhp with a good intake.
This is assuming you are running a quality intake manifold (street heat, performer, ported gt-40 family) along with a 65mm TB and upgraded MAF and full exhaust, pullies, blah blah blah.
There was a thread around here where a guy touched off 300rwhp with a custom cam.
cervinistang
11
Dearborn, Michigan
Dec 7, 2007
#12
  • Dec 7, 2007
  • #12
then what is stock at the wheels?
Taz92gt
54
Knoxville Tn
Dec 7, 2007
#13
  • Dec 7, 2007
  • #13
190-200
90mustangfan
93
So cal
Dec 7, 2007
#14
  • Dec 7, 2007
  • #14
stock RWHP depending on how good of cond. and how many miles it has...190rwhp. On a good fresh low milage motor 200Rwhp, tops.
So you will spend $1500-2000 on good aftermarket parts to only get 230rwhp...I guess 30-40 rwhp is pretty ok, but for the money spend that bad.
jtfairlane
468
#15
  • Dec 7, 2007
  • #15
Taz92gt said:
190-200
Personally I've never seen any stock stangs, with either transmission, put up 200rwhp.
Most stone stock AOD 5.0L mustangs will put down somewhere in the ball park of 175rwhp, most stone stock T5 5.0L mustangs will put down somewhere in the ball park of 185-190rwhp.
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Dec 7, 2007
#16
  • Dec 7, 2007
  • #16
I dare not even guess how sad the numbers would be on my AOD '86 GT 'vert...
Good to know that I could be up around the 240 range if/when I can ever afford to throwing on a set of ported E7's and a decent intake, though.
BlooDReigN
283
Calgary, Alberta
Dec 7, 2007
#17
  • Dec 7, 2007
  • #17
with bone stock heads and cam, 230 is probably the limit, but if you want to put in a crazy ass cam, port the **** out of the heads, put in bigger valves and raise the compression, you would probly see in the high 200's at the wheels. You can get some half decent numbers out of the stock heads with some work in to them. But by the time you've done that, you could have picked up a used set of AFR's and had better numbers. Only worth while if you are requird to stick with the stock heads.
Flavadave4
1,044
21
49
Utica, NY
Dec 7, 2007
#18
  • Dec 7, 2007
  • #18
*scratches head*
But you are spending money in the wrong place by not touching the heads. If you were even to go mild and use some rough figures......
$500 gt40 iron heads
$400 cobra intake
$200 TFS1 cam
$200 65mm TB
$250 MAF
Totaling $1550 and I'd be willing to bet you would clear 230rwhp, prolly be around 250 at the wheels
So thats around 60 more hp to the pavement than stock.....not bad in my eyes.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Monday at 2:12 PM
mattcrp1
M
N
Engine 1994 Mustang GT AODE puzzling issues
  • noah5slow
  • Oct 22, 2022
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Oct 29, 2022
noah5slow
N
SOLD 1993 Mustang Cobra / 114K miles / Modified / Fort Lauderdale, Florida.
  • Naja
  • Oct 4, 2023
12K
Fox Body Mustangs For Sale (1979-93) Feb 26, 2025
Naja
New to me Fox body. Looking for Rough HP and compression ratio
  • Halford4491
  • Oct 30, 2021
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 3, 2021
General karthief
A
93 fox build help
  • anorth93
  • Jun 23, 2020
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 27, 2020
2000xp8
