motor and trany mounts
  • Thread starter Thread starter nickcasta
  • Start date Start date Apr 23, 2008
N
nickcasta
20
worcester ma
Apr 23, 2008
  • Apr 23, 2008
im in the process of putting new motor and trany mounts in my 5.0. im not sure how to remove my drive shaft and when im jacking up my motor and trany to install the new mounts should the car be level?
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 23, 2008
  • Apr 23, 2008
Driveshaft removal is easy. Get a 12mm 12 point box end and remove the 4 bolts that hold the drve-shaft to the pinion of the rearend. Then slide the slip joint out of the tranny. As far as being lvl for the install it isn't as important. Just jack up remove and reinstall. Remeber not to get your fingers somewhere they can get pinched and squished.
samickguy15
404
Delavan, IL
Apr 23, 2008
  • Apr 23, 2008
You might need to unbolt the trans crossmember to get enough room between the trans and crossmember to slide the mount in/out.
vikingpower
656
CWU Ellensburg, WA
Apr 23, 2008
  • Apr 23, 2008
You do NOT have to pull the driveshaft out to swap tranny mounts. Just unbolt the 4 mount bolts, jack the trans slightl off the crossmember, and swap the mounts.
Its always better to find a way of doing things without pulling the DS out, it always makes a friggin mess and you have to top off the trans fluid.
vikingpower
656
CWU Ellensburg, WA
Apr 23, 2008
  • Apr 23, 2008
You shouldnt have to unbolt the crossmember either.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 23, 2008
  • Apr 23, 2008
lol why didn't I catch that. I was just answering his question. MAn obviously you do not have to pull DS. going to be hard to remove with h-pipe connected though isn't it? if you have to remove h-pipe then the DS is going to have to come out.
N
nickcasta
20
worcester ma
Apr 24, 2008
  • Apr 24, 2008
i have to put in a new drive shaft anyway because i drove with bad mounts and it warped my old one like a c haha. when i put a new one in, should i go for an aluminum one? also how do i put new trany fluid in?
the reason im replacing the mounts is because my old ones wore out so bad, the pitch of my engine changed and put all the preasure on my ds. when i put in the new mounts and the new ds will that straighten out the angle of my engine?
Engine Would you replace these OEM motor mounts?
  • 91GTstroked
  • Sep 21, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
Potomus Pete
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
T
Fox *Solved* Motor mount bolt question
  • TDM389
  • Mar 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TDM389
T
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
Engine Radiator with no shroud provision... What to do?
  • FastDriver
  • Apr 22, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
FastDriver
