Motor Mounts
  • Thread starter Thread starter candphall
  • Start date Start date Feb 13, 2012
First Prev 2 of 2
candphall
488
32
49
Orlando Florida
Feb 20, 2012
#21
  • Feb 20, 2012
  • #21
The mounts have arrived, drivers side installed 2 hours and 45 minutes. Passenger side tomorrow.
candphall
488
32
49
Orlando Florida
Feb 20, 2012
#22
  • Feb 20, 2012
  • #22
2+2GT said:
I would bend the poorly-made headers before I misaligned the engine. Steel tubing is a "plastic" material and the headers cold be bent 1/4" or more quite easily to solve your problem. Protect the header tube from the gearbox with thin plywood, pull hard into the geabox, then back the other way. You'll easily get 1/4" clearance this way, at "$0" per inch.
Tried the plywood and nothing moved. And stayed moved. On to the mounts.
2+2GT
3,333
10
79
Southeastern Pennsylvania
Feb 21, 2012
#23
  • Feb 21, 2012
  • #23
You need to be more aggressive.
candphall
488
32
49
Orlando Florida
Feb 21, 2012
#24
  • Feb 21, 2012
  • #24
Well the mounts are installed and what a pleasure. In total I would say that the installation time was about four hours in and out. Once installed It took,only a slight push and I got the clearence that I was looking for. And without damaging the ceramic coating on the headers. I did not use the lowering portion so if anyone can use them they are yours for the asking. All you pay is the shipping.
Monty_Brown
21
#25
  • Feb 21, 2012
  • #25
Good deal!!!!
candphall
488
32
49
Orlando Florida
Feb 22, 2012
#26
  • Feb 22, 2012
  • #26
I have built many high performance cars in the past but this is my first Mustang. I have gotten more aggressive on two occasions in the past. One resulted in crushed tubing the other a crack at the flange. Neither set were poorly made as another member stated. One was Hooker the other Doug Thorley.
First Prev 2 of 2
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Motor mounts question
  • djj62478
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 13, 2026
nickyb
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
