  • SN95 4.6L Mustang Tech
Motor problems
  • Thread starter Thread starter 1Bad96
  • Start date Start date Feb 17, 2006
1Bad96
15
  • Feb 17, 2006
About a year ago I swapped out my blown 96 Gt motor for a 00 Gt motor with 42k on it....i put all my old boltons on the new motor and job was done within a weekend...never tuned it or anything, seemed to be running fine. last fall just before i was about to store the car for the winter i jumped on it from a 40 roll and it started to miss a little bit once i hit 4-4500 rpm. it did it over and over with little varriation so i thought maybe plugs? did that gapped them to spec and didnt help. although ignition was only 2 yrs old i put new coils and wires on it bc one wire was sketchy and the coil has a small crack....it didnt help, i replaced the fuel filter and nothing either....I plugged it into a ford scanner and the only thing was the O2 sensor and the right side was not reading at all....i replaced it and it still does the same slight hesitation at higher rpm....Ive also ran some injector cleaner through it and didnt seem to do anything. Sometimes it will not do it and sometimes it will. Im thinkin its got something to do with fuel but id like to hear some opinions.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Feb 17, 2006
  • Feb 17, 2006
can you drive the car with a scan tool hooked up to it. or atleast a fuel presure gauge. if you can get a FP gauge then tape it to the widsheild and go for a ride. watch the fp when it does this.tell us if it drops. lets make sure you got full fuel presure then we will go from there.
the98stang
2,408
Clovis, CA
Feb 18, 2006
  • Feb 18, 2006
Maybe it's a vac leak?
Try checking the A/F ratio
  • Gulftown980x
  • Jul 29, 2026
squeak93
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
  • brandyn200
  • Jun 20, 2026
AeroCoupe
