as you know, i put shims on the stock rockers because this motor has been milled or something before i got it. before it would not crank with them tight so if i loosen the bolts, it would fire up and run. so i shimmed them .090. that was enough to get the rockers loose.(off of the valves when closed.). i also put an f cam in it a couple days ago.it has blue spark, fuel and air.it is NOT 180 out and i tried both firing orders.i even loosened the rockers and nothing. not even a pop. but i turned the dizzy and the retarded ignition slowed the engine down while cranking. i am pretty sure i put the cam straight up. what gives. it is not even popping like it would if the distributor was out of sink or something. anybody got answers. stock rebuilt e6 heads, rebuilt roller engine stock valve springs, f cam, carbureted. i am stumped and it's pissing me off.
