Ok, lazy me, I purchased a Motorsport EFI harness for my conversion. Got just about everything else done, now just finishing up the last of the wiring. Thought I had gotten everything connected and found a wire with a terminal on it. After checking the instructions, it should connect to "20 gauge Fuse Link to Starter Relay". OK, I know what the fuse link, 20 gauge is, Is the starter relay the same as the starter sol mounted on the passenger side just behind the battery. and if so, which side of the sol. does it connect to?, it has a large dia ring terminal, so I'm guessing, but the instruction manual does not mention the connection other that the description noted above. Help.
