Movement in Steering Wheel
  • Thread starter Thread starter 90blue5.0
  • Start date Start date May 23, 2007
9
90blue5.0
266
Regina, Canada
May 23, 2007
  • May 23, 2007
Is there a bushing or bearing in the steering column that can be replaced. I can litterally move my steering wheel up/down - right/left, it feels like it is worn out and I'd like to get rid of that movement.
cenok is family
1,409
69
79
Norman, Ok
May 23, 2007
  • May 23, 2007
take the column trim off and check to see if all the bolts for the ignition module and everything (all the metal stuff) are tight...my old t top car had a lot of steering wheel movement like that and it turned out to be that.
jspagna1
53
Connecticut
May 23, 2007
  • May 23, 2007
And when you put it back together use Loctite. That took care of the same problem I had on my truck.
9
90blue5.0
266
Regina, Canada
May 23, 2007
  • May 23, 2007
Thank you - that sounds like a cheap fix.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
May 23, 2007
  • May 23, 2007
I did mine last summer....now loose again but I am going to fix it friday after work with loctite
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
May 23, 2007
  • May 23, 2007
oh and my truck (92 Z71) is the same way.
superhuaman
907
Harrisburg, PA
May 23, 2007
  • May 23, 2007
if you need to, there is a bearing you can replace. it is behind the steering wheel and airbag clockspring (if equipped). it cost me about $12.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Swapping clutch pedal hanger-
  • woodsnake
  • Nov 8, 2026
Classic Mustang Specific Tech Nov 8, 2026
woodsnake
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Tuesday at 10:26 PM
AeroCoupe
H
Aluminum timing chain guides ?
  • healy1963
  • May 5, 2026
2005 - 2014 S-197 Mustang -General/Talk- May 5, 2026
healy1963
H
Best Ebay aftermarket Radio/screen
  • Shurkeel
  • Oct 8, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 9, 2026
gkomo
