mpg sucking
i got a 88 na stock latly ive only been getting about 20mpg :mad: i was getting around 24 i think something got messed up when the car overheated on me waterpump went out and radiator got a leak changed it all now and my mpg went down is there anything i could do to get it back up?
If you already have replaced the rad and the water pump try doing the hoses and the clamps that attach them it just might be a bad hose, also see if you have had your thermometer changed when you got your water pump done. Hope this helps
You think thats bad...i've been getting no better than like 80-90 miles per 1/2 tank...and even in the summer i only get like 95 per half at best. I have tried everything(new plugs, fuel filter, complete tune up, timing belt, ect..) and nothing works. I'm begining to think its a valvetrain issue and one of the cylinders isn't firing right. It really sucks putting 5 dollars in reg. and its gone in a day. :mad: :owned: :bang: :(
When your car overheated, did you drive it very far while it was hot? If so you may have warped the head. I over heated my 2.3L and cracked the head. The machine shop told me that the 2.3L head is notorious for cracking during a overheating situation.
If you cracked your head, your car should be running really rough at idle and gas mileage would be terrible.
First id talk to tealstang, hes generally hanging round here somewhere, my friends 5.0 (a 94) gets decent milage 16-25 mpg , ive been around 5.0s enough, but i dont know them as well as a 2.3, so maybe the 5.0 forum could help you?
Have you tried:
A: a new o2 sensor
b: injector cleaner
1:if it is one (or more) of the injectors, you can pull them and have them tested and flow matched , or just replace them
C:loosing some weight in your right foot
You changed the timing belt? did u make sure to time it and its dead on? you are getting spark at every SINGLE plug? New plug wires? Did you get the right plugs, and gap them correctly? Its the small things that usualy cause the most trouble, hope you find the problem !
yea all my plugs are good and wires are good my timing is set tdc i had my mechenic chec the timing for me and it was right is there a way to check th o2 sensor? or should i just replace it ive ran some injector cleaner. also the car runs fine and does not give me any trouble the temprature gets dead center of the gauge and that is as high as it will get then it will drop some.also the tstat works fine
ssjmaverick23 said:
i just looked in my book for my car and i could not find were the o2 sensor is can yall tell me were it is at thanx
Take a look the hole that is nearest to you is the O2 bung where the O2 sensor goes. Keep in mind that I have a Ranger header but it should be in the same place on the Mustang header.
Have you tried:
A: a new o2 sensor
b: injector cleaner
Yes, the timing was on cause the reason we put the new one in was cause i wouldn't hold timing. We made sure it was perfect. I've tried injector cleaner several times. The o2 sensor is almost exactly a year old. I'm at a loss at this point. And i drive the thing like a grandma :(
hmm, if your sensors are new, injectors are in good spraying order, you dont drive like a bat out of you know where, maybe a vaccum leak is cuasing the computer to dump extra fuel , making it run rich. This should cuase other sides affects, but it may not be. I'd say check for vaccum leaks if all the above mentioned is running right. After that, lol im not sure what to look for?
