My car's had an MRT catted H-pipe:
for a while now and seemed to be losing power, gradually, for some time. It dyno'd surprisingly low before the cam installation and afterward, the numbers weren't great but okay. I had it tuned locally a year ago and the car put down an okay 274HP but a recent dyno test showed it to be down to 260 again. This was done after failing an emissions sniffer test rather miserably (I had a WB connected on the dyno to see what the A/F was like and it's spot on...) Fuel trims are all right where they should be so the tune is fine. In order to pass emissions, I put the factory 4-cat H-pipe back on and not only passed emissions with flying colours, I'm sure the car has picked up power too. I can only think at this point that the MRTs cats, one or both, are clogging or otherwise done, even though I can't visually inspect the cats due to the pipe bends to be sure.
So now I'm debating what to do. I was thinking one of two things:
1) Obtain replacement cats for it (I believe they're Magnaflow parts originally) and have them welded in.
2) Go to a different midpipe, possibly a Bassani catted X.
I'm leaning towards '2' but would appreciate other opinions. Also, does anyone know the replacement catalytic part number for these if I do choose to go with '1'?
