  • SN95 4.6L Mustang Tech
MRT PONY BALL SHIFT KNOB INSTALL
  • Thread starter Thread starter 8cyl
  • Start date Start date Jun 4, 2004
8cyl
74
South Jersey
Jun 4, 2004
  • Jun 4, 2004
anyone install one of these before?
How the hell do you make it tight. The instructions say...use a wrench to tighten the jam nut. The only problem is, you can't put a wrench on it, because it goes inside the freakin knob.
WTF, how the hell do you tighten it?
twogts4us
4,188
12
79
Dunedin, FL
Jun 4, 2004
  • Jun 4, 2004
Hmmm, looks like I have the same knob just without the pony on it. I guess I don't understand how the jam nut would go up inside the knob...is it recessed on the underside? That would make it difficult! Let me go snap a pic of the underside of mine and I'll upload it - be right back (digital - the only way to go!)
8cyl
74
South Jersey
Jun 4, 2004
  • Jun 4, 2004
cool man...
yeah the nut is recessed. I don't see how the hell I'm supposed to tighten it
twogts4us
4,188
12
79
Dunedin, FL
Jun 4, 2004
  • Jun 4, 2004
See attached close up of mine; the boot is pushed down a little so you can see better...
When installing this knob, I pushed the boot down, ran the jam nut down the handle, spun the knob on to my liking, then held it in place and ran the jam nut up to the knob by hand then a little tweak with an adjustable wrench to lock it in place. Then I pulled the boot up as tightly as I could.
The only thing I can think of on yours is that maybe the brass sleeve is getting pushed up into the knob?
Let me know how it turns out...
8cyl
74
South Jersey
Jun 4, 2004
  • Jun 4, 2004
thanks for the pic....
Mine is different, maybe i can get a pic tomorrow.
The brass section is recessed into the knob. It came like that. The nut goes up into the knob, and there is no way I can tighten it.
Time to call MRT i guess
twogts4us
4,188
12
79
Dunedin, FL
Jun 4, 2004
  • Jun 4, 2004
Well, if you can't tighened the jam nut, can you thread it to about where you want, then holding jam nut with your fingertips (or needlenose pliers or ?) and tightening the knob down to the jam nut? It may take a bit of trial and error...
KaPPaBaLL
1,326
BAYAREA
Jun 4, 2004
  • Jun 4, 2004
FATKNOBS FOR LIFE FAWKERS!!
BDRs02BlkGT
62
Fort Riley, KS
Jun 5, 2004
  • Jun 5, 2004
I have the same knob and what I had to do was keep backing up the jam nut. Then just I tightened the knob down until it lined up where I wanted. It took several tries until I got it where I wanted it but it looks really good and hasn't move at all.
twogts4us
4,188
12
79
Dunedin, FL
Jun 5, 2004
  • Jun 5, 2004
Yep, that was my thought in the above post...kinda crazy that you have to fight with it this way, but I think it'll work, with a bit of trial and error. From what I've seen, he's installing his Tri-Ax tomorrow, so with this info, he should be good to go.
Hey, don't forget 8cyl, give us a progress report & pics tomorrow - we wanna see!
ADRENLN
2,342
NJ
Jun 5, 2004
#10
  • Jun 5, 2004
  • #10
listen to my biggest mustang mistake yet! when i was putting my knob on, i became so frustrated with trying to get it perfect and to stay that way; lets just say the knob is now thread locked to the shifter. god that was so stupid. opps
what ever u do dont do that.
abouttobeglue
529
birmingham al
Jun 5, 2004
#11
  • Jun 5, 2004
  • #11
ive had 2 hurst shift bALLs black and white. i could always twist the knob a little more each day until i broke it. the first time i bought a ew ball, th second time i bough some super glue,hadnt noved sice
Cobra Jay
889
Motor City
Jun 5, 2004
#12
  • Jun 5, 2004
  • #12
I got a Bullitt shift knob from CDC. $55, look bad a$$ and easy as hell to install. No jam nut or anything, just screw it on and you're done.
bigDogs02GT
74
#13
  • Jun 5, 2004
  • #13
Mine was the same way, I got the white knob. I used a screwdriver against the flat edge of the nut from up underneath and basically used trial and error tightening the knob against the nut until it was where I wanted it. Damn thing took me almost 45 minutes to install and I had to pick up a date. Needless to say she was a bit *#@!ed at me. Hope that helps!
8cyl
74
South Jersey
Jun 5, 2004
#14
  • Jun 5, 2004
  • #14
UPDATE
I just bought a wider nut. It works great. I can get a wrench on it cuz it hangs down a little.
Thanks for all the help!
twogts4us
4,188
12
79
Dunedin, FL
Jun 5, 2004
#15
  • Jun 5, 2004
  • #15
Hey, at least you have your priorities straight! JK!
D
Interior and Upholstery Shift knob doesn’t connect to shift boot?
  • dqureshi06
  • Jun 10, 2025
Fox 5.0 Mustang Tech Jun 17, 2025
Kid wita 5oh
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
P
Suspension Different height ball joints?
  • pindude80
  • Jun 10, 2024
3K
Fox 5.0 Mustang Tech Jun 12, 2024
limp
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
