Msd 6al2 Install Question!!
Apr 24, 2014
70
I got all the wires ran correctly on the car except the gray tach wire, i wired it to the freen and yellow striped wire and i lose all spark, but when removed car sparks, what color wire is the correct one?
And low and behold
Reactions: jrichker
I may be wrong about this because its been awhile since I wired one of these. But, I'm pretty sure that if you use the TFI wiring harness you do not need to use the tach output wire.
Reactions: jrichker
Right on target for use with the stock tach.! :)
The TFI module dark green/yellow wire feeds the stock tach and the computer. Make sure it is connected just like the stock setup.
Only aftermarket tachs use the MSD tach connection.
Diagrams courtesy of Tmoss & Stang&2birds
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Ignition switch wiring
O2 sensor wiring harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangO2Harness.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
Visual comparison of the Ford Fuel Injectors, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Ford_Injector_Guide.jpg
