I'm exciting. I ordered mine today. Should be able to get it put in within the next 2 weeks, and I'll be doing a write-up for it. Just had to tell someone, and wanted to tease you guys
http://www.msdignition.com/new_products/8734.html
MSD said:Ford Launch Master
The Launch Master connects right to your late model Ford to produce consistent launches and quicker 60-foot times by setting an rpm limit to stage with. When activated, the rpm will be held at a steady rpm and once the green light comes on, release the clutch and take off - but be sure to hold on! The rpm is adjusted with two built-in rotary dials ranging from 1,800 - 9,900 rpm in 100 rpm increments. A handy LED shows when the launch rev limit is active.
- Easily set a launch rpm for consistent holeshots
- Connects to the factory coils for easy installation
- The best way to launch hard
