MSD Digital Window Switch 8969 Install help
You will need to tap the odd colored wire going into the ingnition coil located on top of the spark plug. You only need to do this on one coil. This is only true for the COP(coil on plug) 4.6's.
Is the odd colored wire the negative wire for a coil pack? I ask this because in the MSD Installation Instructions for the Tach Driver (PN 8913), there is a "Figure 5 Connecting to coil per cylinder Ford and Chevy" that shows the red coil wire as the positive wire.
:shrug:
Of all the things I've done to my car this one just doesn't make any sense to me, I'll have to get a pic of an engine so you can point to where its is that you guys are talking about because I'm spaced out
