MSD distributor
  • Thread starter Thread starter gtstang1987
  • Start date Start date Dec 13, 2007
G
gtstang1987
  • Dec 13, 2007
I am installing a MSD distributor and for the life of my i can't get it in there. Any suggestions on what might be the problem. The oil pump rod that sticks into the bottom of the distributor keeps falling to the side i think that might be the problem, so i used a little greese to keep it from falling over and it still wont go in. Ive compared it to the distributor i pulled out and there identical, as far as length and gear. Any help would be awesome. Thanks
goodfastncheap
100
Bellevue, NE
Dec 13, 2007
  • Dec 13, 2007
The cheapest tool you have in your toolbox is also the most important - patience.
wiggle, stab, wiggle stab, wiggle. stab stab wigg.....
jtfairlane
468
  • Dec 13, 2007
Sounds like you didn't install the retainer/washer on the oil pump drive shaft that keeps the oil pump shaft from being pulled out of the pump/block.
I don't envy your attempt to try and install the oil pump driveshaft from above, while also installing the distributor...
EMW150
2,020
Roaring Spring,PA
Dec 13, 2007
  • Dec 13, 2007
Use the grease to center the shaft. I usually use the white assembly lube because it'll disolve. Set the distributor in and then you need to turn the engine over by hand with a ratchet on the balancer till it drops in the rest of the way. What's happening is the hex on the shaft isn't aligning in the bottom of the distributor gear. No problem, common when installing a distributor.
stykthyn
5,232
2,652
223
gainesville
Dec 13, 2007
  • Dec 13, 2007
I ran across a situation like this before. like said earlier the shaft is lifting up and not letting the dist sit the way it is supposed to. get a pair of needle nose and see if you cant get it to drop down. then try and isntall your distributor.
Fast63
717
  • Dec 13, 2007
I do not agree with trying to center the shaft, I think it is really unnecessary because I have never had a problem with it. It's ok if the shaft falls to the side, it doesn't matter. But turning the engine over by hand is key, but you can also do it much more easily by just turning the starter over for half a second. The problem you are having is like these guys said with the hex shaft needing to mate with the hex in the distributor. If you bump the starter like I said, it will rotate until it mates properly and you don't have to worry about screwing anything up because the distributor gear and cam gear are already meshed. But make you you have it is far enough that they are meshed!!
G
gtstang1987
  • Dec 14, 2007
Thanks all for the advice. I haven't tired bumping the starter or manually turning over the motor i thought i might strip the gear but that does make since that the gears are already mated. I will attempt this again when i get off work this afternoon. Thanks again
EMW150
2,020
Roaring Spring,PA
Dec 15, 2007
  • Dec 15, 2007
I should've explained a little better. The shaft doesn't need to be perfectly centered but I've installed distributors before where the shafts were missing the clips and layed totally to one side when trying to install. In that case the taper won't start into the bottom of the dist. shaft. When I ran into that I spaced it out slightly with white grease so it'll start right in.
Fast63
717
  • Dec 15, 2007
The clips don't have anything to do with the shaft falling to the side, it just keeps the shaft from pulling out. If you have had problems with that in the past, it was something different. The hole in the block is really not all that much bigger than the shaft is. In fact I just installed my distributor today and the shaft was to the side and touching the block. It finds its own way into the hole.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
P
Engine Swapping EFI distributor for carb distributor- shaft length is different
  • pindude80
  • Jul 20, 2024
Fox 5.0 Mustang Tech Jul 21, 2024
pindude80
P
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Resolved 1985 3.8 tbi, Only starts with fluid then runs great
  • broomtail78064
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 28, 2025
AeroCoupe
R
91 5.0l cranks but no start, fuel pump keeps priming
  • Rhubyn
  • Jun 16, 2024
2K
Fox 5.0 Mustang Tech Jul 29, 2024
4cylredfox89
