msd ignition
If you are near stock, not running power adders, your ignition (and dizzy) are in good shape, and dont live at redline, IMHO you probably wont see any difference.
Others' opinions might vary.
As stated earlier, the best upgrade for more rpm would be better valve springs. If your still using the factory computer you wont be able to rev much higher than 6200 without a rpm extender. The stock ford dizzy isn't that bad. People run in the 9's with them. I would upgrade the coil before the distributor...PB
With a stock or near stock engine, power drops off dramatically after 5100 RPM. This is a function of the flow restrictions in the lower intake and heads. A ported TMOSS lower or Explorer intake is the inexpensive fix and will extend the power upwards maybe another 200-300 RPM.
To make good power above 5400 RPM, you'll need better heads. At that point, more power is a function of how many $$$ you want to spend. Spend more and you get more HP at higher RPMs.
Upgraded ignition on a stock motor will do nothing performance wise, but it sure is a cool box to have under the hood.
A S/C'd motor is really where the box (and it's ability to adjust timing) comes to light.
Stock computer rev limit is 6250... You would need to go into the computer to remove that limit before going higher.
