MSD Ignition
  • Thread starter Thread starter savegoodautonfg
  • Start date Start date Aug 11, 2006
savegoodautonfg
1,085
  • Aug 11, 2006
What exactly does MSD Ignition do for you?
Mustang78
486
Aberdeen, WA
Aug 11, 2006
  • Aug 11, 2006
it pts a cool red aluminum box on your firewall...plus gives hotter spark and multiple sparks during the power stroke, vs. the stock 1 spark, hence the name MSD-multiple spark discharge, thats all i know so good luck, and the 6AL has a rev limiter, the 6A does not
~Mark~
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Aug 11, 2006
  • Aug 11, 2006
yeah and they look spiffy
L
luckythirteen13
648
Anaheim, CA
Aug 11, 2006
  • Aug 11, 2006
instead of firing once, the coil fires 6 times for each cylinder below 3000rpms and one big spark above 3000rpms. most coils loose power as the rpms rise, the msd box will prevent that, allowing for full voltage from the coil at all rpms
savegoodautonfg
1,085
  • Aug 11, 2006
Anyone have a used one i could buy
Mustang78
486
Aberdeen, WA
Aug 11, 2006
  • Aug 11, 2006
check ebay they're about 140 new, and the procomp (fake MSD) is 90 new..good luck and let us know how what you end up buying works
~Mark~
HISSIN50
34
129
Aug 11, 2006
  • Aug 11, 2006
FWIW, the stock ignition is robust. It should be good for upwards of 400 HP N/A. And there is one guy in particular I know of who is running 10 pounds of boost with a stock ignition and not having flame out issue.
Good luck.
T
tbi92rs
69
Louisville, KY
Aug 11, 2006
  • Aug 11, 2006
Um 6Al's are 230 new, not 140!
D
dwhiskie
183
  • Aug 11, 2006
Burn up...... then you got a paper weight
Fett
766
#10
  • Aug 11, 2006
  • #10
Basically if you have a N/A setup, or a mild build up, you don't need an MSD.
I am hooking mine up tomorrow, on my mild, n/a, 5.0...but I have my reasons. I want a hard rev limiter, which I will set at 6k...and I will be adding a power adder shortly, I just don't know which one.
If you want a cheaper alternative, I do have a ProComp 6AL (imitation MSD 6AL) that has never been used but has been opened. I bought it to save a few bucks ($140 for the ProComp vs $200 for the MSD), but the other day I was getting it ready to install and I heard a rattle from inside. So I popped the bottom cover off and found that one of the heatsinks was not fastened. There are two of them that are screwed to the case itself, and one of them didn't have the screw holding it down..the screw was loose. I decided to not put it in my car and will be putting it on eBay for $50 + shipping as soon as I get a picture.
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
C
For Sale Mint 1993 Calypso 5.0 Convertible
  • Chrispy62
  • Aug 22, 2026
Fox Body Mustangs For Sale (1979-93) Aug 22, 2026
Chrispy62
C
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
W
1993 LX 5.0 dies after ignition parts replacement
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
4K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
M
Electrical Wiring issue
  • Maxnie21
  • Mar 23, 2025
Fox 5.0 Mustang Tech Mar 27, 2025
Maxnie21
M
