  • 1994 - 1995 Specific Tech
msd install help
  • Thread starter Thread starter fballplayya82
  • Start date Start date Jul 11, 2008
F
fballplayya82
28
  • Jul 11, 2008
2 questions.
1 where is my stock ignition box and im guessin i just remove it and pull all the wires that were attached to it?
2 where do most of u guys mount the box, install should b eas b/c i got the harness
thanx
9
94v6GT
141
  • Jul 11, 2008
there isnt a stock ignition box. if you have the harness, take the coil plug and plug it into the MSD, then run the new plug back to the coil and your 85% done. do you have instructions? search MSDignition.com
hollywoodstang
1,095
Jul 15, 2008
  • Jul 15, 2008
Omg please read or download the instruction from MSD before you do ANYTHING. I am just saying...
M
madams74
664
Maryville, TN
Jul 15, 2008
  • Jul 15, 2008
Sure there is a stock module / box. The location is on the passenger side fender wall. It is located near the bottom of the inner wall in front of the strut tower. It has an aluminum heat sink with large fins and has the plug installed in it. The module uses the aluminum to cool itself. These used to be installed on the distributor but Ford knew they had an overheating issue, so it was relocated away from the engine. You can use the harness at the coil for the MSD box. You need to use the + wire for the coil and follow those directions you get from MSD. They do sell a plug n play adapter to make it easy if you do not want to hack into the factory wiring.
F
3G Alternator install question
  • fathead429
  • Oct 24, 2026
1974 - 1978 Mustang II Talk & Tech Oct 25, 2026
LILCBRA
  • dan50
  • Jul 18, 2026
dan50
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
