MSD ready to Run
  • Thread starter Thread starter palerider94
  • Start date Start date Jun 6, 2006
P
palerider94
573
  • Jun 6, 2006
Ordered a MSD ready to run dist for my 302 auto. Soundlike you can change springs and bushing to advance curves - just curious if anyone has installed one and what your experience was with changing springs and bushings. Thanks
mudbilly
175
South County, Maryland
Jun 6, 2006
  • Jun 6, 2006
I have one but I never changed any of the springs or bushings. I tried to understand all the timing/power curves that they supplied but for the way I drive I didn't think that I'd see/feel any difference.
I figgered that the way it came from the factory was probably how 99% of them get installed anyway.
spirockp
5 Year Member
Mar 26, 2004
465
12
39
NJ
Jun 6, 2006
  • Jun 6, 2006
Mudbilly. The first thing your suppost to do is change the springs to the lightest ones. It will make your foot responce and motor revs increase so much quicker. You will definitly notice the difference. Besides that, that was all I touched.
mudbilly
175
Jun 6, 2006
  • Jun 6, 2006
i will try that.............should i leave the bushings the way they are??? they only change the rpm that it stops advancing?? correct???
nevermind, i just reread your post about not changing anything else
Tim65GT
1,149
West Texas
Jun 6, 2006
  • Jun 6, 2006
Here is a link:
http://www.msdignition.com/pdf/8350_8352_8354_frm23728.pdf
I bought one. It was waaaay easier than the Accel I had.
I think I used one light silver spring and one light blue for the advance rate.
The amount of advance was the blue or silver bushing.
I wrote it down, but it was a while back. It's been running great, so I've had no reason to mess with it.
mudbilly
175
Jun 7, 2006
  • Jun 7, 2006
drove the car to work this morning with the strong springs.........just changed to the weakest springs during lunch, took less than 10 minutes
can't wait for the ride home........
i'll post tomorra with my review
P
palerider94
573
  • Jun 7, 2006
Look forward to the review
Look forward to the review. Got it yesterday - opening the box I felt like a kid at christmas - will put on this weekend.
67Dylan
259
Phoenix, AZ
Jun 7, 2006
  • Jun 7, 2006
hrspwrjunkie said:
That's not true.
The springs, which change the advance rate and the bushings which limit total advance used in conjunction with the initial timing you set needs to be taylored to the specific engine combination you have.
A couple of the difficulties you may find with advancing the timing too quickly is that you will either have to limit total advance to a level which won't be optimal for higher RPMs because of premature ignition or advance at that rate is just too fast for the combination, period. That isn't to say it didn't work for your combination, but it isn't advice that will work with every engine combination out there.
Yes sir. Thanks for clarifying for everyone; tune the car properly is most important for optimal performance.
mudbilly
175
Jun 8, 2006
  • Jun 8, 2006
well the car ran like crap with the lightest springs.. ..the exhasut sounded crappy like it had an miss or something............lots of detonation under acceleration
i stopped half way home and put back in the heaviest springs, the one it was shipped with
i probably won't experiment anymore because my car has always run good the way it was, but i'd be interested in hearing what you finally do.
67Dylan
259
Phoenix, AZ
Jun 8, 2006
#10
  • Jun 8, 2006
  • #10
If you played w/the timing a bit, changed the springs, played w/timing some more, you'd get more response than w/the heavy springs. I'm assuming your car isn't stock. It's not really a drop in job. You have to see where total timing comes in at, what is total timing; a slight process. See the 2 posts above my last one for the WHY.
spirockp
5 Year Member
Mar 26, 2004
465
12
39
NJ
Jun 8, 2006
#11
  • Jun 8, 2006
  • #11
My experience was right out of the box the car drove OK but it seemed like I was draging a house. As soon as I changed to the lighter springs which made it advance quicker, the car just now takes off. I'm running a 302 at about 290 horse.
67Dylan
259
Phoenix, AZ
Jun 8, 2006
#12
  • Jun 8, 2006
  • #12
What's your total advance at? What RPM does it kick in at?
spirockp
5 Year Member
Mar 26, 2004
465
12
39
NJ
Jun 8, 2006
#13
  • Jun 8, 2006
  • #13
I don't recall what my total advance is.
"What RPM does it kick in at?" I'm not sure I know what your asking? All I know is I hit the gas and the car just takes off. Much better then the Mallory I was running with before.
67Dylan
259
Phoenix, AZ
Jun 8, 2006
#14
  • Jun 8, 2006
  • #14
At what RPM is it at full advance? Just curiosity questions, that is all.
Great68
691
Victoria BC
Jun 9, 2006
#15
  • Jun 9, 2006
  • #15
I have one as well, I have played around with the springs and found that one silver and one blue works well for my motor.
However, what I'd like to know (Maybe someone can answer) is how to heck to get at the advance stop bushing? Is it possible without taking the distributor out?
C
93 Tubular A Arm Bushings
  • Chrispy62
  • Jul 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 31, 2026
Chrispy62
C
Door glass fastener question
  • limp
  • May 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 25, 2026
limp
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
2003-04 Mustang Cobra Brake Conversion
  • Cassiebaebae
  • Oct 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 24, 2026
Bib36`
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
